Test version of SuperTuxKart 0.8.1 for the AmigaOne X1000
Hi all,
I have released a test version of SuperTuxKart 0.8.1 for the AmigaOne X1000.
Download: supertuxkart-0.8.1-test-svn14394-altivec-linux-glibc2.13-ppc.tar.gz
Could you test this version, please?
Rgds,
(909.2 KiB) Downloaded 392 times
trevordick
A-Eon Technology
A-Eon Technology
Re: Test version of SuperTuxKart 0.8.1 for the AmigaOne X100
Post by trevordick »
Christian, downloag and gave quick test, using the Ubuntu Remix HDD install...looking very good so far. Well done! :-)
Trevor
I'm just Breezin'
trevordick
A-Eon Technology
A-Eon Technology
Spoke too soon,
Caused a kind of log out on shutting down the program. Eventually fell back to login screen? (kernel 3.12)
Trevor
I'm just Breezin'
Post by zzd10h »
SuperTuxKart is the only reason for me to boot on Linux,
But will be better with joystick support.
is it supported in this version ?
Thank you
trevordick wrote:Spoke too soon,
Trevor
Hi Trevor,
Thank you for testing. :) I have tested it with the kernel 3.12 and Lubuntu 12.04.3 but I don't have this issue. Happened it always if you have closed STK? Or happen it only sometimes?
Rgds,
zzd10h wrote:Hi,
Thank you
Unfortunately not. My future plan is, adding joystick support in STK on the AmigaOne X1000. ;)
Post by zzd10h »
Will be great !
I've also released a test version for non X1000 user. You need a PC or Mac with a 32-bit Linux system.
Download: supertuxkart-0.8.1-test-svn14394-linux-glibc2.7-i386.tar.bz2
trevordick
A-Eon Technology
A-Eon Technology
Multiple log out loop occurred when I shut down STK.
Will do some more test to see if I can repeat the problem.
Trevor
I'm just Breezin'
tommysammy
Post by tommysammy »
Trevor when open the Amistore? I want purchase the Ubuntu Live-DVD
