Kernel 3.12
Kernel 3.12
Hi all,
The Linux 3.12 kernel was released yesterday: http://www.phoronix.com/scan.php?page=n ... px=MTUwMzA. I have modified a bit Darren's patch and compiled the kernel 3.12.
Download: vmlinux-3.12.0AmigaOneX1000.tar.bz2
Rgds,
trevordick
A-Eon Technology
A-Eon Technology
Re: Kernel 3.12
Post by trevordick »
Well done Christian. I presume 3d gfx acceleration and all other AmigaONE X1000 specific devices work OK with the new Kernel?
I will start testing later in the week.
Trevor
I'm just Breezin'
Re: Kernel 3.12
trevordick wrote:Well done Christian. I presume 3d gfx acceleration and all other AmigaONE X1000 specific devices work OK with the new Kernel?
Hi Trevor,
Yes, that's right. The 3D gfx acceleration and sound works on my AmigaOne X1000. Could you also test the kernel 3.11, please?
All the best,
trevordick
A-Eon Technology
A-Eon Technology
Re: Kernel 3.12
Christian,
Posting from the Remix Installation using Darren's 3.11 kernel. All OK :-)
I will try with your 3.12 kernel next.
Trevor
I'm just Breezin'
Re: Kernel 3.12
trevordick wrote:Christian,
Trevor
Thanks for testing. :)
mechanic
Re: Kernel 3.12
Post by mechanic »
3.12 is working OK with Wheezy.
I would ask if you could please increase the number of serial ports to 4.
It should have no effect if only the 2 onboard ports are available.
Looks good.
zappa2009
Re: Kernel 3.12
Post by zappa2009 »
I get 2 error Messages at Boot Time that the Kernel could not load 2 Kernel Modules from /lib/modules/3.12.....
loop is one Module.
Please release 3.12 Kernel_Modules too as it is in the 3.11er Package.
Re: Kernel 3.12
zappa2009 wrote:I get 2 error Messages at Boot Time that the Kernel could not load 2 Kernel Modules from /lib/modules/3.12.....
loop is one Module.
Here you are: vmlinux-3.12.5AmigaOneX1000.tar.gz :)
- added modules directory
- It based on the bug fix version of the vanilla kernel 3.12.5
- added kernel modul for 3Dfx video cards
Have a lot of fun with the new kernel. :)
zappa2009
Re: Kernel 3.12
Post by zappa2009 »
It works good :mrgreen:
Fast Boot and good Response. NICE !
Re: Kernel 3.12
Does someone tested a 3dfx voodoo card in the A1-X1000?
