HP ScanJet 4400c USB
my_pc_is_amiga
Is there way to configure fxScan or other scanning software to work with a HP USB scanjet 4400c on OS4 using the OS4 native stack?
Re: HP ScanJet 4400c USB
Do you already take a look at xsane & amicygnix ?
http://os4depot.net/index.php?function= ... /xsane.lha
It works fine with my HP5400 USB.
my_pc_is_amiga
Thanks a lot--I didn't now about this program! I was quite amazed. Installation was easy, no setup required and it just detected it. Works nicely on the 4400c scanner as well.
