Hi X1000 owners!
I do have a problem since day one - both AmigaOS and Linux (first was Ubuntu now is Debian 7) simply
don`t restart the machine (hard restart, not AmigaOS soft reset, 3 fingers salute). In fact machine
does restart but simply machine doesn`t show X1000 boot screen or sends any video signal to monitor.
Shutdown surely works and on turning on everything works like charm.
Is this isolated problem of mine, and what would be the cause, or other X1000 users have similar glitch?
Hard reset / reboot fails
Future MOS user pon SAM460ex
- trevordick
- A-Eon Technology
Re: Hard reset / reboot fails
Question: This could be an OS4/card issue. Which RadeonHD gfx card do you have installed?
In Linux, with the latest Kernesl you can login & out and shut down the machine. I don't think I have ever used reset?
Trevor
Trevor
I'm just Breezin'
Thanks Trev,trevordick wrote:Question: This could be an OS4/card issue. Which RadeonHD gfx card do you have installed?
Trevor
Radeon Bart (6000HD series, see my signature)
Can you please try a restart / reset from Linux and hard reset using PUFF under AmigaOS?
Seems to be CFE/Uboot or GFX card thing related to 6000 or 7000HD cards,
also reported on SAM460
http://www.amigans.net/modules/xforum/v ... 68&forum=4
I believe Hans has somewhere explained it is x86 BIOS on GFX card thing,
and presumably solution would be some kind of PPC Flash, like Mac Cards had.
- Hans
No, the solution wouldn't be some kind of PPC Flash. For starters, nobody makes PPC firmware for these cards. Using an interpreter to execute x86 code is simply the way that things work these days.vox wrote:I believe Hans has somewhere explained it is x86 BIOS on GFX card thing,
FWIW, I have never had a hard-reset (done by pushing the reset button on the case) fail with any card that I've tested. Did you use the reset button, or Ctrl+alt+alt? It's worth trying both.
Hans
Other people have experienced this (Not me), take a look at this page, see if the instrutions here help:vox wrote:Hi X1000 owners!
http://wiki.amigaos.net/index.php/AmigaOne_X1000
Regards
Darren
OK, soon I all be adding RAM and SSD so my fat technician will take a look at PSU.daz wrote:Other people have experienced this (Not me), take a look at this page, see if the instrutions here help:vox wrote:Hi X1000 owners!
Regards
Darren
When I say HARD RESET I mean SOFTWARE FULL RESTART - HARD REBOOT and not RESTART by using hardware button on case.Hans wrote:vox wrote: FWIW, I have never had a hard-reset (done by pushing the reset button on the case) fail with any card that I've tested. Did you use the reset button, or Ctrl+alt+alt? It's worth trying both.
Hans
There is no RESET BUTTON on x1000 case as far as I can see ...
You have to look harder thenvox wrote: There is no RESET BUTTON on x1000 case as far as I can see ...
No you have read blogsRaziel wrote:You have to look harder thenvox wrote: There is no RESET BUTTON on x1000 case as far as I can see ...
There is reset button (we ll I would not call it a button) once door
is opened, but its not acessable since I keep it closen unless DVD is used.
That is hard solution, but yet the problem remains.
Thanks for your help and solidarity, as usual.
No you just have to open your eyesNo you have read blogs And have Quickstart Manual shipped with your X1000, probably.
Just to add my X with a RadeonHD 6870That is hard solution, but yet the problem remains.
...i don't have that problem
Sensible questions get sensible answersThanks for your help and solidarity, as usual.
