This is modified manual based on my experience on Mint 11.
Soon I will propose what should be better stressed in great X1000 Linux Debian and others manual
Herby I salute my friend @knight
http://forum.opensource-srbija.org/user/303-knight/ that has spend whole day and night
playing with my Master Miggy.
PRE-REQUISITES / INTRO
Why Mint 11 PPC? http://www.mintppc.org/ Well, it takes best of Debian and Mint, mixes it with light LXDE and makes
way faster distro then Ubuntu 12.04 LTS REMIX. If its my penguin taste, this should be
our supported distro
However, note that Ubuntu does comes with some newer software,
no need to insert kernel and does have Firefox 22 instead of Iceweasel. And is about 2-3x slower
(my subjective experience). At the other hand, Debian files are tested and way more stable release.
None have Flash support on PPC, use HTML5 (youtube.com/html5) whenever possible.
HAVE FAST INTERNET
If you intend to use Net version of Mint11 / Debian 7.2. install good side is smart
CD to download and you will get most recent files (no need to update after install)
but it will take thousands of small files downloaded. Pick US mirrors or fastest
mirrors from your location, have a real fast net!
READ THE MANUALS
Note these files are accessable only to registered X1000 users
Firmware guide
http://secure.a-eon.biz/download/AmigaO ... e-v5.1.pdf
Linux install guide
http://secure.a-eon.biz/download/Debian ... X-1000.pdf
Get to know your CFE. Read whole Linux install guide as most important steps are listed in ordinary
Linux Debian install. Read Mint 11 specific install.
Text in bold are file paths that may vary depending on current Debian and X1000 kernel,
as well as device of your choice to use DVDs, USB flash or Card Reader during install.
BE SMART
Dont follow the procedures blindly, think is that path / partition on your computer.
Read everything on screen. Have a skilled Penguin around. Be patient. Love your X1000
COMPIZ PROBLEM
Compiz and Screen Applets are great, but can so easily spoil the LXMDE desktop.
Avoid it unless stable release that does no evil appears. And it slows down the gfx
performance.
CFE>
CFE> are commands in Firmware mode. Enter CFE by pressing F on X1000 boot menu.
KNOW YOU FILES
Once in CFE there is no way to access files and see them. Check and write
down ALL FILE PATHS of KERNELS AND LINUX INSTALL FILES.
X1000 KERNEL
Get the latest X1000 specific kernel from XENO and good guys.
IDEALLY IF YOU CAN COPY IT TO CARD READER AS IT WILL BE OF PERMANENT USE AFTER INSTALL.
DO NOT DELETE THOSE FILES ONCE LINKED TO LINUX AND CFE BOOT MENU COMMAND,
it MAY RENDER LINUX BOOT IMPOSSIBLE.
IF YOU USE USB
Make sure its FAT16 formatted, CFE cannot read FAT32/NFTS. Also, insert USB Flash drive
AFTER YOU ENTER CFE
Recommended method is shorten kernel, LInux net install file names and Kernel names
and to have them ideally on CF in X1000 (NEEDS EXTERNAL CARD READER, YOU CANNOT SEE
CF IN AMIGA OS 4.1.6, only in Linux)
HERE WE GO!
INSERT DEBIAN V7.2 PPC64 NETINSTALL DISK
DURING BOOT-A ENTER FIRMWARE BY PRESSING F ON X1000 BOOT SCREEN
CFE> ramdisk -z -addr=0x24000000 -fs=iso
atapi0.1:install/powerpc64/initrd.gz /PATH TO INIT FILES OF LINUX INSTALL
CFE> setenv bootargs "root=/dev/ramdisk install url=mintppc.org”
/PATH TO DOWNLOAD MINTPPC FILES
CFE> boot -elf -noints -fatfs
cf0:vmlinuz /PATH TO KERNEL
DEBIAN WILL REPORT ERROR OF NOT HAVING PROPER KERNEL, CONTIUE
WHEN ASKED FOR NETWORK TAKE PA SEMI ONBOARD ETHERNET, BE SURE YOU ROUTER IS CONNECTED TO IT
REPARTITION HARD DRIVE IF NEEDED, DO NOT TOUCH AMIGA DH PARTITIONS. TAKE A NOTE THAT AT THIS
STAGE ROOT MUST BE EXT3 FORMATTED. MOUNT EXT3 ROOT WITH / AND MOUNT /HOME IF NEEDED
AS WELL AS SWAP PARTITION IF NEEDED/. /CHECK AND WRITTE DOWN WHAT IS YOUR ROOT SDA - which SDA
My drives scheme
SCSI 1 (0, 0, 0) (sda) - 2.0 TB ATA MOUNT POINT
#1 121.9MB affs7 BDH0
#2 109.8GB B DH0
#3 40GB F ext3 dhx /
#4 80GB F swap dhx swap
#5 491.5GB F ext3 dhx /home
#6 1.4TB DH1
SCSI 7 (0, 0, 0) (sdb) 129.0MB ATA ATP COMPACT FLASH
#1 PRIMARY 128.5MB B FAT16
SCSI 8 (0, 0, 0) (sdc) 4.0GB VERBATIM STORE N GO
#1 4.0GB FAT16
AFTER SETTING MOST BASIC THINGS UNDER LINUX - LOCALE - USER AND ROOT A THOUSANDS
FILES WILL BE DOWNLOADED FROM NET. TAKE A WALK, BE WITH PERSON YOU LIKE
After reboot re-enter CFE as described.
CFE> setenv -p bootargs “root=/dev/sda3“ /HERE USE YOUR /HOME SDA SDA
CFE> setenv -p boot_debian "ramdisk -max=20000000 ide0.0:/boot/initrd ; boot -elf -noints -fatfs cf0:vmlinuz" /LOADS KERNEL FROM CARD
boot_debian
MAKING BOOT MENU - DEPENDS ON YOUR MENU CONFIG
CFE> setenv -p MENU_2_COMMAND "boot_debian"
CFE> setenv -p MENU_2_LABEL "linux mintppc 11"
TEST IT BY USING COMMAND MENU and choice
SETTING 3D ACCELERATION
In LINUX TERMINAL
/etc/init.d/gdm stop /STOPING GFX SERVICES
Root YOUR PASSWORD
ls /etc/X11
mkdir /etc/X11/xorg.conf.d
nano /etc/X11/xorg.conf.d/10-vsync.conf /ENTERING TEXT EDITOR, type in it:
Section "Device"
Identifier "Radeon HD 6870 " /DEPENDS ON YOUR CARD
Option "SwapbuffersWait" "False"
EndSection
CTRL + X, confirm with Y
nano /etc/profile.d/radeon_sh
# export LIBGL_DRIVERS_PATH=/usr/lib/xorg/modules/dri_g/
# export R600_ENABLE_S3TC=1
export vblank_mode=0
export CLUTTER_VBLANK=none
HOW TO TEST GFX CARD
Enter terminal, type glxgears - without 3D it will be 60 fps with it 1500 fps and up depending on card
After this you should insert newly created user (in my case vox( in sudoers user group - LXDE menu USERS AND GROUPS
If you wish to use encrypted DVDs install libdvdcss2 via Synaptic or software manager
At this time it is libdvdcss2.1.2.10-0.3_powerpc.deb
sudo /home/vox/ARCHIVE/x1000 files/libdvdcss2.1.2.10-0.3_powerpc.deb (This is not mentioned in manual for this to work you have to be sudoers group of users and needs a restart to work)
sudo dpkg --install /home/vox/ARCHIVE/x1000 files/libdvdcss2.1.2.10-0.3_powerpc.deb
/home/vox ... is path where I downloaded it.
COMPIZ INSTALL:
sudo apt-get install xcompmg (You need to add scrinlets via Synaptic, this is also lacking in manual)
gedit /etc/xdg/lxsession/Mint-LXDE/autostart
And edit file and add to the end
@xcompmgr -n
Save file.
/etc/init.d/gdm stop /SHUTDOWN xorg server: ROOT ONLY
Enter root username and psw in terminal
su
/etc/init.d/gdm start
If you wish not to use compiz re-edit the mentioned file with line @xcompmgr -n and save it, restart
BUG REPORT: Lower LXDE panel might discappear, or something else might go wrong on LXDE desktop.
SOLUTION: DELETE HIDDEN FILES top and bottom in /home/vox/.config/... and RESTART. New LXDE
desktop will be generated during boot
ENJOY MINT 11 POWERPC64!
