Boot speed up and recommendations for X1000 dockies
vox
Post by vox »
Dear Amigans,
I recently recieved X1000 with OS 4.1.6 and Ubuntu LTS 12.04
Two set of questions:
a) How to permanently set set pmu=А4 )to 1800Mhz) since it halves the Linux boot time
and presumably AmigaoS 4 boot time? I believe I have read CFE has been updated, too?
b) On AmigaOS side, I deeply miss PUFF (Turn off/Reset tool), LED and CPU Temp dockies are not part of the X1000 AmigaOS
since they are really needed. I will compile set of recommendations for AMIGA FEATURE REQUESTS
More to come!
Future MOS user pon SAM460ex
danbeaver
Re: Boot speed up and recommendations for X1000 dockies
Post by danbeaver »
As to A), I just followed the instructions in the included manual, and for B) those dockies are on the OS4Depot web site for download and work fine for my X1000. Well, POff sometimes hangs...
vox
Post by vox »
danbeaver wrote:As to A), I just followed the instructions in the included manual, and for B) those dockies are on the OS4Depot web site for download and work fine for my X1000. Well, POff sometimes hangs...
Thanks, beaver.
Which one? CFE manual?
Yes this is additional software, but as I did, you surely missed HDD activity LED; way to see CPU temp and to hard restart AmigaOS.
This features should become part of OS.
danbeaver
Post by danbeaver »
The speed ups (increase in CPU speed and decrease time to pick boot device) are in the CFE manual.
The case lacks an led for HDD activity, but the motherboard has a header; I added an LED trapped between the case and front fascia; the LED docky works once configure for the sb600ide.device -- also a download from OS4Depot site.
The X1000 is not the only computer running OS4.1 and I'm sure the folks don't want to bloat-ware the install with too many options, but as soon as you install the dockies you prefer, and make a backup, they are then part of the install. 8-)
vox
Post by vox »
danbeaver wrote:The speed ups (increase in CPU speed and decrease time to pick boot device) are in the CFE manual.
I said X1000 release :-) Thanks for LED tip, such a great case - such a great fail (I would put even DVD light up the case, since I like to keep case closed).
Anyhow, since its essential it could go in EXTRAS :-)
Phantom
Post by Phantom »
I use X1kTemp, LED Docky (very handy) and POff without the slightest problem.
Christopher Follett
AmigaKit
AmigaKit
Post by Christopher Follett »
Phantom wrote:I use X1kTemp, LED Docky (very handy) and POff without the slightest problem.
Ive heard its not 100% accurate. Can anyone confirm this.
Resolute and Industrious
__________________
New Products
Depends...which of the dockies do you refer to?
People are dying.
How dare you!
– Greta Thunberg
sundown
Post by sundown »
X1kTemp .................. CFE show temp
Case - 36C ............... local - 36C
CPU - 44C ................ remote1 - 50C
Core1 - 51C ............. remote2 - 45C
Core2 - 46C ............. remote3 - 44C
Temps match if you move them around, X1kTemp labels may not be right, but I'd say the docky temps are accurate.
Ken
Ah, ok.
I remember that the docky did go through some output changes...abalaban (the author?) wrote (OS4Depot.net comments?) that he mistakenly put some readings to the wrong outputs and "fixed" that.
So either cfe is "still" wrong or the docky was "fixed" to be broken :-)
People are dying.
How dare you!
– Greta Thunberg
