attempting to start the screen blanker on my system today after the various updates, i receive a DSI error, after which the task doesn't exit cleanly. the system is a pegasos2 running AOS 4.1 update 6 with the latest components available on the public update server. here is the crash log:
Crash log for task "BlankerModule"
Generated by GrimReaper 53.16
Crash occured in module GLNoof.blanker at address 0x7DCF4DA4
Register dump:
0: 00000018 60E4BF50 3929C480 605C93A0 FFFFFFFF 021B69A6 6375F930 0000FFFF
8: 00000000 00000000 00000000 8000FFFF 60E4BFFC 7C7E1B79 00000000 67932940
16: 02260000 EFD06F20 02260000 5FEB5DB0 00000000 00000000 018436D4 7F93F510
24: 6375F930 00000000 FFFFFFFF 021B69A6 5FEB5DB0 0000001F 66460000 65516BF0
0: 65536 196 31 196
4: 2 413.8 235.8 196
8: 2 128 413.8 255
12: nan 65536 0 0
16: 0 0 0 0
20: 0 0 0 0
24: 0 0 0 0
28: 0 0 0 0
Machine State (msr) : 0x0000D030
Condition (cr) : 0x60E1F608
Instruction Pointer (ip) : 0x7DCF4DA4
Xtended Exception (xer) : 0x679EBDF4
Count (ctr) : 0x6FF894D0
Link (lr) : 0x7FADC918
DSI Status (dsisr) : 0x60E1F3C0
Data Address (dar) : 0x019B77EC
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x7DCF4DA4 belongs to module "GLNoof.blanker" (HUNK/Kickstart)
Stack trace:
module Sys:Utilities/Blankers/GLNoof.blanker at 0x7DCF4DA4 (section 5 @ 0x1D80)
module LIBS:screenblanker.library at 0x7F93F5DC (section 5 @ 0x15B8)
native kernel module dos.library.kmod+0x00024f18
native kernel module kernel+0x0004357c
native kernel module kernel+0x000435fc
PPC disassembly:
7dcf4d9c: 7c601850 sub r3,r3,r0
7dcf4da0: 81230000 lwz r9,0(r3)
*7dcf4da4: a8090030 lha r0,48(r9)
7dcf4da8: 2f800000 cmpwi cr7,r0,0
7dcf4dac: 419e008c beq- cr7,0x7DCF4E38
System information:
CPU
Model: Motorola MPC 7447/7457 Apollo V1.1
CPU speed: 999 MHz
FSB speed: 133 MHz
Extensions: performancemonitor altivec
Machine
Machine name: Pegasos II
Memory: 1048576 KB
Extensions: bus.pci bus.agp
Libraries
0x652ab9c8: WallChop.AmIPlug V2.1 (Legacy)
0x68ad87f4: vapor_toolkit.library V15.12 (Legacy)
0x021b69a6: exec.library V53.58
0x6ff84804: vilintuisup.library V0.9
0x6ff846d8: cgxvideo.library V42.1
0x6ff660e0: cybergraphics.library V43.0
0x641bad68: GLNoof.blanker V2.0
0x6524f6d8: faad.library V2.1
0x60dc2030: 8svx.datatype V53.1
0x60dc20d0: sound.datatype V53.6
0x60dc22b0: Floattext.mui V20.225
0x63669f50: NFloattext.mcc V19.71
0x6523ee9e: Mailtext.mcc V19.9 (Legacy)
0x63669e10: Aboutbox.mcc V20.42
0x5ea551b4: camd.library V53.6
0x644fc9c8: bz2.library V53.2
0x63669cd0: Pixmap.mui V20.32
0x6464d4a8: Generic_Mouse.driver V52.1
0x644fc848: usbhidgate.library V52.2
0x6464d328: Generic_usb.driver V53.3
0x6464d268: PCI_GamePort.driver V53.1
0x651fbcd8: PCI_GamePortHornet.driver V52.2
0x651fb618: PCI_Soundcard.driver V52.2
0x651fbc18: PCI_sblive.pci V52.1
0x651fbb58: PCI_SoundCardHornet.driver V52.2
0x651fb9d8: Generic_Keyboard.driver V52.1
0x651fb918: PCI_CatweaselJoystick.driver V53.1
0x6057c9d8: AmigaInput.library V53.1
0x6525f0b0: getcolor.gadget V53.9
0x636690f0: gradientslider.gadget V53.6
0x63669234: colorwheel.gadget V53.6
0x63669050: ascii.datatype V53.3
0x636697d0: text.datatype V53.5
0x67931aa0: expat.library V53.3
0x636692d0: getscreenmode.gadget V53.8
0x67927f18: minigl.library V2.5
0x63a5b6f0: Warp3D.library V53.18
0x5fe318c8: W3D_R200.library V53.21
0x5fe319c8: W3D_Avenger.library V53.1
0x5fe31c48: W3D_Napalm.library V53.1
0x5fe312c8: W3D_Permedia2.library V52.42
0x63669368: W3D_Picasso96.library V53.10
0x63f9dd60: Volumelist.mui V20.238
0x63f9de00: Dirlist.mui V20.424
0x651fb4ac: muilocale.library V20.363
0x63f9dea0: Poppen.mui V20.296
0x63f9db80: Popmenu.mui V20.107
0x63f9da40: Lamp.mcc V20.40
0x63f9d900: Dtpic.mui V20.220
0x63f9d720: Popasl.mui V20.229
0x65287334: asyncio.library V50.3
0x6524f4d8: pthreads.library V53.9
0x6524b1e8: dvdvcd.plugin V51.4
0x67932220: avcodec.library V51.52
0x6524bf68: a52.codec V52.2
0x6524b9e8: dca.codec V51.1
0x651fb338: speedbar.gadget V53.12
0x6536acf8: radiobutton.gadget V53.9
0x632e8b48: amissl_v097g.library V3.7
0x63f9d558: amisslmaster.library V3.7
0x63f9d4a0: ilbm.datatype V53.2
0x63f9d400: Imagedisplay.mui V20.230
0x63f9d2c0: Pendisplay.mui V20.221
0x63f9d180: TheButton.mcc V26.12
0x63f9d0e0: TheBarVirt.mcc V26.12
0x65252840: TextEditor.mcc V15.41
0x652528e0: NListtree.mcc V18.42
0x65252980: BetterString.mcc V11.25
0x6524c6d0: ttengine.library V7.2
0x6523e820: simplehtml.library V0.21
0x6524df4e: Busy.mcc V17.37 (Legacy)
0x652521f8: xenbar.image V20.213
0x642733e8: XDCC.AmIPlug V1.4 (Legacy)
0x642732e8: CManager.AmIPlug V1.5 (Legacy)
0x652523e0: Listtree.mcc V20.124
0x65252480: Levelmeter.mui V20.333
0x65252520: Gauge.mui V20.255
0x651e4bae: Textinput.mcc V27.1 (Legacy)
0x65252660: NListview.mcc V19.90
0x652527a0: NList.mcc V20.135
0x67923c5c: codesets.library V6.15
0x679ded2c: muimaster.library V20.2351
0x645f4298: update.library V53.12
0x651f6710: fuelgauge.gadget V53.8
0x6528b640: texteditor.gadget V53.20
0x6523e698: SubDock.docky V53.1
0x6523e618: Separator.docky V53.2
0x6523e598: Clock.docky V53.10
0x65734910: slider.gadget V53.13
0x65734870: getfont.gadget V53.9
0x657347d0: arexx.class V53.3
0x65734690: getfile.gadget V53.11
0x66459954: device.audio V6.2
0x650edb18: screenblanker.library V53.3
0x6536a038: clicktab.gadget V53.39
0x65641190: requester.class V53.18
0x65734370: space.gadget V53.6
0x65734190: bitmap.image V53.9
0x651b0f40: integer.gadget V53.10
0x650ecaa8: chooser.gadget V53.18
0x657340f0: penmap.image V53.5
0x651b0ea0: checkbox.gadget V53.9
0x650ec1e4: filesave.audio V6.3
0x650eb864: asl.library V53.49
0x679f3c48: listbrowser.gadget V53.61
0x68c9d020: string.gadget V53.16
0x651b0180: scroller.gadget V53.13
0x683bdc18: via-ac97.audio V5.9
0x68e6f5d4: usergroup.library V4.30
0x685ea990: jpeg.datatype V53.5
0x681a31b8: emulation.library V53.1
0x681aca60: bsdsocket.library V4.307
0x683baa5c: textclip.library V52.2
0x68ae69fc: hid.usbfd V53.8
0x68ae6084: xpkmaster.library V5.2
0x68ae6130: mathieeedoubbas.library V52.1
0x68c3d3fc: xadmaster.library V13.1
0x68c06a50: button.gadget V53.15
0x68c06af0: glyph.image V53.3
0x68be19b0: window.class V53.50
0x68a16708: popupmenu.class V53.2
0x68c2e098: popupmenu.library V53.8
0x68c069b0: label.image V53.12
0x68a16538: layout.gadget V53.19
0x68a16610: bevel.image V53.6
0x68c06910: drawlist.image V53.3
0x68c064b0: png.datatype V53.6
0x68c46cb4: picture.datatype V53.6
0x68c9ee6c: ft2.library V53.1
0x6ff0a80c: workbench.library V53.51
0x68c9f870: Picasso96API.library V53.4
0x68bea8a0: gadtools.library V53.6
0x68c9d768: timezone.library V53.8
0x68d12e38: application.library V53.12
0x6ffa89bc: commodities.library V53.1
0x68c8fd40: datatypes.library V53.4
0x68c48084: png.iconmodule V53.1
0x68c5f8cc: icon.library V53.13
0x68c42148: version.library V53.11
0x68c405d0: iffparse.library V53.1
0x6fcc51cc: locale.library V53.6
0x6ff617ac: diskfont.library V53.4
0x6fcca628: petunia.library V53.4
0x6fcca568: diskcache.library V3.30
0x6fc76690: dos.library V53.145
0x6ff84bc4: usbprivate.library V53.12
0x6fe850bc: massstorage.usbfd V53.13
0x6fe85028: bootkeyboard.usbfd V52.3
0x6ff8ff18: bootmouse.usbfd V53.1
0x6ff84a7c: hub.usbfd V53.8
0x6ff849cc: usbresource.library V53.12
0x6ff60478: hunk.library V53.4
0x6ffa9414: elf.library V53.19
0x6ff894d0: intuition.library V53.43
0x6ff43150: rtg.library V53.30
0x6ff8f820: ATIRadeon.chip V53.26
0x6ff8f7a4: PCIGraphics.card V53.5
0x6ffab7a0: keymap.library V53.3
0x6ff866e0: layers.library V53.7
0x6ffb8420: graphics.library V53.6
0x6ff60044: nonvolatile.library V53.5
0x6ff93498: newlib.library V53.28
0x6ff951ac: utility.library V53.5
0x6ffab0a8: expansion.library V53.1
0x6fca0cae: rexxsyslib.library V53.4 (Legacy)
Devices
0x6789f024: lpr.device V44.6
0x5fe311d4: printer.device V53.1
0x64210684: clipboard.device V53.2
0x681a6884: ahi.device V6.6
0x68b556f4: diskimage.device V52.78
0x68d122f8: prism2.device V2.5
0x6ff95b10: usbsys.device V53.12
0x6ff60730: ohci.usbhcd V53.19
0x6ff60690: uhci.usbhcd V53.12
0x6ff605c4: sii3114ide.device V53.15
0x6ff8fba4: peg2ide.device V53.15
0x6ffa8338: console.device V53.1
0x6ff963f0: ramdrive.device V52.6
0x6ffab9ec: input.device V53.4
0x6ff613b4: keyboard.device V53.10
0x6ff962d0: timer.device V53.1
-- eliyahu
