SLIDER_Invert, TRUE, wrong with scrollwheel
javierdlr
Post by javierdlr »
Hi, just adding 'SLIDER_Invert, TRUE,' tag to an already ReAction example (OpaquenessExample.c) makes when you use the scrollwheel the slider goes up/down wrongly.
OpaquenessExample.c source:
Hidden Text - Click to Show :
;/* ReAction example of Opaqueness (and slider gadget) by Alex Carmona
gcc -Os -o OpaquenessExample OpaquenessExample.c -Wall -Wextra -lraauto -lauto
quit
#define ALL_REACTION_CLASSES
#include <reaction/reaction.h>
#include <reaction/reaction_macros.h>
#include <intuition/intuition.h>
#include <intuition/gui.h>
#include <intuition/icclass.h>
#include <proto/intuition.h>
#include <proto/exec.h>
#include <proto/dos.h>
Object *win;
struct MsgPort *AppPort;
enum
    OBJ_INTEGER_1,
    OBJ_SLIDER_1,
    OBJ_INTEGER_2,
    OBJ_SLIDER_2,
    OBJ_QUIT,
    OBJ_NUM
Object *Objects[OBJ_NUM];
#define OBJ(x) Objects[x]
#define GAD(x) (struct Gadget *)Objects[x]
/* These structs are used to link the slider gadget and integer gadget together */
/* so that changing the value of one gadget updates the value of its counterpart */
struct TagItem slider_to_int[] = { {SLIDER_Level, INTEGER_Number}, {TAG_END, 0} };
struct TagItem int_to_slider[] = { {INTEGER_Number, SLIDER_Level}, {TAG_END, 0} };
Object *
make_window(void)
    return WindowObject,
        WA_ScreenTitle,         "Reaction Example",
        WA_Title,               "Opaqueness Example",
        WA_DragBar,             TRUE,
        WA_CloseGadget,         TRUE,
        WA_SizeGadget,          TRUE,
        WA_DepthGadget,         TRUE,
        WA_Activate,            TRUE,
        WA_Width,               200,
        WA_Opaqueness,          255,    /* Initial opaqueness on opening (0..255) */
        WA_OverrideOpaqueness,  TRUE,   /* Override global settings? (TRUE|FALSE) */
        WA_FadeTime,            500000, /* Duration of transition in microseconds */
        WINDOW_IconifyGadget,   TRUE,
        WINDOW_IconTitle,       "Iconified",
        WINDOW_AppPort,         AppPort,
        WINDOW_Position,        WPOS_CENTERSCREEN,
        WINDOW_Layout,          VLayoutObject,
            LAYOUT_SpaceOuter,      TRUE,
            LAYOUT_AddChild,    OBJ(OBJ_INTEGER_1) = IntegerObject,
                GA_ID,              OBJ_INTEGER_1,
                GA_RelVerify,       TRUE,
                GA_TabCycle,        TRUE,
                INTEGER_MaxChars,   3,
                INTEGER_Minimum,    10,
                INTEGER_Maximum,    100,
                INTEGER_Number,     50,
                INTEGER_SkipVal,    10,
            End, // Integer
            Label(" Fade Time (1/100s) "),
            LAYOUT_AddChild,    OBJ(OBJ_SLIDER_1) = SliderObject,
                GA_ID,              OBJ_SLIDER_1,
                GA_RelVerify,       TRUE,
                SLIDER_Min,         10,
                SLIDER_Max,         100,
                SLIDER_Level,       50,
                SLIDER_KnobDelta,   10,
                SLIDER_Orientation, SLIDER_HORIZONTAL,
                SLIDER_Ticks,       11,
                SLIDER_ShortTicks,  TRUE,
                ICA_TARGET,         OBJ(OBJ_INTEGER_1), /* link to integer gadget */
                ICA_MAP,            slider_to_int,      /* map of linked tags */
            End, // Slider
            LAYOUT_AddChild,    OBJ(OBJ_INTEGER_2) = IntegerObject,
                GA_ID,              OBJ_INTEGER_2,
                GA_RelVerify,       TRUE,
                GA_TabCycle,        TRUE,
                INTEGER_Minimum,    55,
                INTEGER_Maximum,    255,
                INTEGER_Number,     255,
            End, // Integer
            Label(" Opaqueness "),
            LAYOUT_AddChild,    OBJ(OBJ_SLIDER_2) = SliderObject,
                GA_ID,              OBJ_SLIDER_2,
                GA_RelVerify,       TRUE,
                SLIDER_Min,         55,
                SLIDER_Max,         255,
                SLIDER_Level,       255,
                SLIDER_Ticks,       21,
                ICA_TARGET,         OBJ(OBJ_INTEGER_2), /* link to integer gadget */
            End, // Slider
            LAYOUT_AddChild,        Button("_Quit",OBJ_QUIT),
            CHILD_WeightedHeight,   0,
        End,  // VLayout
    End;  // WindowObject
} // make_window
int main()
    struct  Window      *window;
    struct  DrawInfo    *Dri = NULL;
    BOOL    canfade     = FALSE;
    uint32  specialfx   = 0;
    uint32  fade_time   = 50;
    uint32  opaqueness  = 255;
    uint32  delay       = 0;
    /* make sure our classes opened... */
    if (!ButtonBase || !IntegerBase || !WindowBase || !LayoutBase || !IntuitionBase)
        return (30);
    if (( AppPort = IExec->CreateMsgPort() ))
        win = make_window();
        if (( window = RA_OpenWindow(win) ))
            uint32  sigmask = 0,
                    siggot  = 0,
                    result  = 0;
            uint16  code    = 0;
            BOOL    done    = FALSE;
            /* These attributes have to be set after opening the window */
            /* because the sliders were created after the integers */
            IIntuition->SetGadgetAttrs(GAD(OBJ_INTEGER_1),window, NULL,
                ICA_TARGET,         OBJ(OBJ_SLIDER_1),
                ICA_MAP,            int_to_slider,
                TAG_DONE);
            IIntuition->SetGadgetAttrs(GAD(OBJ_INTEGER_2),window, NULL,
                ICA_TARGET,         OBJ(OBJ_SLIDER_2),
                TAG_DONE);
            IIntuition->GetAttr(WINDOW_SigMask, win, &sigmask);
            /* Check that compositing is enabled in GUI prefs */
            if (( Dri = IIntuition->GetScreenDrawInfo(window->WScreen) ))
                IIntuition->GetGUIAttrs(NULL, Dri, GUIA_SpecialEffects, &specialfx, TAG_END);
                canfade = (BOOL)specialfx;
            while (!done)
                siggot = IExec->Wait(sigmask | SIGBREAKF_CTRL_C);
                if (siggot & SIGBREAKF_CTRL_C)
                    done = TRUE;
                while ((result = RA_HandleInput(win, &code)))
                    switch(result & WMHI_CLASSMASK)
                        case WMHI_CLOSEWINDOW:
                            done = TRUE;
                        break;
                        case WMHI_GADGETUP:
                            switch (result & WMHI_GADGETMASK)
                                case OBJ_QUIT:
                                    done=TRUE;
                                break;
                                case OBJ_INTEGER_1:
                                case OBJ_SLIDER_1:
                                    if (canfade) /* we only make changes if compositing is enabled */
                                        IIntuition->GetAttrs(GAD(OBJ_INTEGER_1), INTEGER_Number, &fade_time, TAG_DONE);
                                        IIntuition->SetAttrs( win, WA_FadeTime, fade_time * 10000, TAG_END );
                                break;
                                case OBJ_INTEGER_2:
                                case OBJ_SLIDER_2:
                                        IIntuition->GetAttrs(GAD(OBJ_INTEGER_2), INTEGER_Number, &opaqueness, TAG_DONE);
                                        IIntuition->SetAttrs( win, WA_Opaqueness, opaqueness, TAG_END );
                                        /* Calls to SetAttrs() return immediately so we add a delay to allow */
                                        /* the window to finish fading before the next call, in case the user */
                                        /* changes the opaqueness faster than the current fade_time setting. */
                                        delay = fade_time/2; // (1 tick = 2/100s)
                                        IDOS->Delay(delay);
                                break;
                            }  // switch
                        break;
                        case WMHI_ICONIFY:
                            /* override user setting to (de)iconify instantly */
                            IIntuition->SetAttrs( win, WA_FadeTime, 0, TAG_END );
                            if (RA_Iconify(win)) window = NULL;
                        break;
                        case WMHI_UNICONIFY:
                            window = RA_OpenWindow(win);
                            /* restore previous fade_time set by user */
                        break;
                    } // switch
                } // while result
            } // while !done
        } // if window
        IIntuition->DisposeObject(win);
        IExec->DeleteMsgPort(AppPort);
    } // if AppPort
    return (0);
} // main
salass00
Re: SLIDER_Invert, TRUE, wrong with scrollwheel
Post by salass00 »
@javierdir
Does the slider seem to move erratically for you as well (i.e. sometimes left, sometimes right) or is it just my mouse wheel acting up? That is the behavior what I get when trying it on my Beta system at least.
Edit:
I've fixed the bug. The fix will be in the next slider.gadget version.
javierdlr
Post by javierdlr »
salass00 wrote:@javierdir
Yes, with 'SLIDER_Invert,TRUE' it jumps up/down (left/right), when you omit such tag it moves up/down (left/right) smootlhy. Maybe some signed/usigned bug?
salass00
Post by salass00 »
javierdlr wrote:Maybe some signed/usigned bug?
It wasn't that but as I wrote above it is fixed now. The problem was in the scrollwheel handling only.
javierdlr
Post by javierdlr »
Great. THX for so fast fix!!!
javierdlr
Post by javierdlr »
Teste slider.gadget 53.13 and now with 'SLIDER_Invert,TRUE' scrollwheel works as expected :-)
BTW can I change the scroolwhell step, now it moves only 1 unit up/down?
Antoher doubt, when waiting for 'WMHI_MOUSEMOVE' I get '0x000F0000' obtained from
(result = IIntuition->IDoMethod(objects[OID_MAIN], WM_HANDLEINPUT, &code)) != WMHI_LASTMSG )
The slider gadget ID is 1 (this 0001 should appear in the 'result' variable), but I get '0x000F 0000' instead of '0x000F 0001'
000F0000 code=255
WMHI_MOUSEMOVE (000F 0000) ->slider gadget following mouse
sliderVal=100(65600)
000F0000 code=255
00020001 code=100
WMHI_GADGETUP (0002 0001) ->slider gadget released
Or am I missing something?
TIA
salass00
Post by salass00 »
javierdlr wrote: BTW can I change the scroolwhell step, now it moves only 1 unit up/down?
No. It's hard coded to 1 currently (it used to be faster or slower depending on how fast you moved the wheel but that was changed some revisions ago according to the release notes).
000F0000 code=255
000F0000 code=255
00020001 code=100
TIA
The WMHI_MOUSEMOVE messages don't have a gadget ID in them (they are equivalent to IDCMP_MOUSEMOVE from a regular intuition window).
If you want to get notifications from the slider as it's moved instead of just when it's released you need to use ICA_TARGET (set to ICTARGET_IDCMP if you want them to be sent to your window's IDCMP port). Also since there is no WMHI_xxx equivalent for IDCMP_IDCMPUPDATE you need to use an IDCMP hook function.
If you need more information you can look here:
http://wiki.amigaos.net/index.php?title ... rget&go=Go
javierdlr
Post by javierdlr »
@salass
Ok thx, nothing I can do with scrollwheel then. :-)
THX again, will read carefully such links.
