atheros WLAN driver
utri007
atheros WLAN driver
Post by utri007 »
Neil Cafferkey is trying to make atheros based wlan cards to work with Sam series. If somebody who has a some knowledge of those boards could read following thread and maybe could suggest something to solve mythical problem?
http://www.amigans.net/modules/xforum/v ... 6&start=60
PS.
Driver works at least with x1000
Re: atheros WLAN driver
Next step would be to verify that that your card is working 100% by testing it in a PC if you have not done that yet.
You can have a bad device and the normal device info still shows up in Ranger.
Learned this the had way with a PCIEx1 to PCI adapter.
These are the interrupt lines that I get with a pci ethernet card .
Slot 3
(84.27 KiB) Downloaded 633 times
Slot 2
(81.46 KiB) Downloaded 633 times
ncafferkey
Post by ncafferkey »
Multiple SAM users have the same symptoms when using this driver, so I don't think it's a case of a bad card. The driver works with the A1SE, Peg-II and X1000.
It looks like interrupts are not being received by the driver. Could an OS developer investigate if there is a possible interrupt configuration problem specific to these cards, or should I get in touch with ACube?
I'd also be interested to know if these cards work under Linux in SAMs.
If the two Sam 440ep-Flex users with the cards want to try to install linux and test the cards they can have a look at this thread.
http://forum.hyperion-entertainment.biz ... =10&t=1024
It has a link to a custom install iso for the Sam 440ep-flex and some instructions.
The install worked for me when I put the iso together but I have not used it again for some.
ssolie
Post by ssolie »
ncafferkey wrote:It looks like interrupts are not being received by the driver. Could an OS developer investigate if there is a possible interrupt configuration problem specific to these cards, or should I get in touch with ACube?
Please contact ACube directly. If there is a configuration issue then Max will find it.
