AmiDock Docky icon and Composition Effect OFF
javierdlr
Post by javierdlr »
Hi, if WB is using without composition Effect my Mixer docky is rendered wrong (seems using the old image icon image).
When using with Composition Effect ON the docky shows/renders perfectly.
Has anyone a clu how to solve it?
aii.iconType = APPICONT_Docky;
aii.info.dockyBase = DockyBase;
case DOCKYGET_RenderMode:
 *msgData = DOCKYRENDERMODE_Icon;
break;
case DOCKYGET_Icon:
 *((struct DiskObject **)msgData) = GetDiskObject(mixerfullpath);
break;
Changing to 'aii.iconType = APPICONT_ProgamIcon;' (alas no docky functionality, not what I want) the icon shows good on booth Composition Effect ON/OFF cases.
TIA
Re: AmiDock Docky icon and Composition Effect OFF
Post by thomasrapp »
Try GetIconTags instead of GetDiskObject. It's a stupid restriction of icon.library that it does not store the new style icon if a program uses GetDiskObject.
javierdlr
Post by javierdlr »
thomasrapp wrote:Try GetIconTags instead of GetDiskObject. It's a stupid restriction of icon.library that it does not store the new style icon if a program uses GetDiskObject.
Sorry for delay :-)
YES, changing to
   *((struct DiskObject **)msgData) = GetIconTags(mixerfullpath, ICONGETA_FailIfUnavailable,FALSE, TAG_END);
Fixes the wrong remaping of the icon if Composition Effects disabled.
zillion THX mate!!!! :-D
kas1e
Post by kas1e »
@all
I create BZ about fixing that restriction, but it was said by devs its not a bug, but should be like this. So, nothing can be done then.
