ABIT WPL-01 Airpace on sam460 (PCI-E 1x card)
Godfather
Post by Godfather »
Dear,
try today a WLAN PCi-e card to activate the atheros device. Version from 30.8.2013 - The WLAN Card is a ABIT WPL-01 Airpace. I use the sam460ex with the latest ubot and AOS 4.1.6
Unfortunately the card isn´t recognize - Ranger doesn´t show the card under PCI - the device can´t find a card. whats wrong ? please advise.
btw. the card works great in my abit pc under windows.
Kind Regards Godfather
Re: ABIT WPL-01 Airpace on sam460 (PCI-E 1x card)
Did you enable the PCIe x1 slot by the Jumper setting and uboot vairiable as explained in the Sam460ex manual page 8 ?
Godfather
Post by Godfather »
Yes, an PCIe soundcard works without any problems.
Kind Regards
Godfather
Check to see if the card is recognized by Uboot.
To do this get in to the Uboot Shell then type pci 03 and then enter key.
If the card is recognized then you should get a pciid.
Godfather
Post by Godfather »
... nothing ! no pci information.... seams that the uboot / sam460 have a timing problem during the init phase. is there a uboot command to increase the init phase ?
Kind Regards
Godfather
Godfather
Post by Godfather »
get the info from acube that the uboot doesn´t support some pcie bridge. the bridge of the abit is also not supported ! :-(
The supported bridges that I know work are the Pex 8112 and the ASM1083/1085 .
You may be able to use a Pex8112 pciex1 to PCI adapater and a PCI version wireless card.
Or use a a Wi-Fi ethernet Hub .
http://www.iogear.com/product/GWU647/
