Mixer contents to be in Commodities? (SOLVED!)
HKvalhe
Post by HKvalhe »
The main Mixer and the contents in Commodities
Mixer drawer with contents in Commodities
Recently, there has been an update to the Mixer tool, and it now includes an own drawer with its' contents.
The question is: Where to put the Mixer drawer with its' contents and the main Mixer (in the drawer)? Should they be in SYS:Utillities/Commodities in the Mixer drawer?
In the past, there was ONLY the main Mixer tool, and of course i had it in SYS:Utillities/Commodities. I suppose the new Mixer drawer with all the Mixer contents and the main tool, should be in the Mixer drawer placed in the Commodities, right?
Are these correct? (See attached screenshots)
Helge Kvalheim, Norway
AlexC
Re: Mixer contents to be in Commodities?
Post by AlexC »
It's up to you, if you don't like having it in there you can move it elsewhere and adjust the IMAGEPATH or SKIN tooltype.
The only thing it needs is the images drawer so you could have only the Mixer exe and images drawer in Commodities.
HKvalhe
Post by HKvalhe »
AlexC wrote:It's up to you, if you don't like having it in there you can move it elsewhere and adjust the IMAGEPATH or SKIN tooltype.
Thanks :) It was found out that with the latest version of the Mixer, it's place would best be left in SYS:Utilities in its' own Mixer drawer, where all its' contents also are.
As i am using the ESI@Juli XTe PCIe audio card, it doesn't support the Mixer. However, i am to understand that Lyle is working on a Mixer for both the X1000 HD audio and audio systems like ESI@Juli :)
I would say that this is now solved :) The right place is SYS:Utilities in the Mixer drawer :)
