Amiga OS 4.1 (update 6 and radeonHD driver last release) boots fine when using the radeon's HDMI port connected to a Samsung TV (HD ready).
But... When using the exact same system with the mini display port connected to an Apple 27 display (mini displayport), I can see the firmware screen (in a purple color), then the "loading kickstart files" screen (in a purple color) and then... A (forever) black screen.
When using a DVI to mini display port converter (dual link Kanex C247DL), the monitor remains black at boot time, then i see the Amiga OS 4.1 logo (colors are fine), then... forever black again...
I tried the INTERRUPT=NO option in the monitor tooltypes but it does not fix the issue.
Thanks!
Black screen at boot time on a Sam460ex - Apple 27 minidp
Re: Black screen at boot time on a Sam460ex - Apple 27 minid
Same problem with a 24 inches Apple mini displayport.
Did you try to disable DDC?
Im not sure if AOS supports screens larger than 1920x1200.
I'll try that. thx
- Hans
Sorry, but DisplayPort is not supported by the RadeonHD driver.Amiga OS 4.1 (update 6 and radeonHD driver last release) boots fine when using the radeon's HDMI port connected to a Samsung TV (HD ready).
Assuming that connecting a DVI monitor to the graphics card works fine, this is 100% the converter's fault.When using a DVI to mini display port converter (dual link Kanex C247DL), the monitor remains black at boot time, then i see the Amiga OS 4.1 logo (colors are fine), then... forever black again...
I had a look at the reviews for the C247DL on Amazon, and 4 out of the 9 complain about it not working as it should. Some are complaining about black screens, being unable to use a screen > 1280x720. That doesn't sound promising.
Hans
- Hans
It does.ZeroG wrote:Did you try to disable DDC?
Hans
First of all, thanks for your reply.Sorry, but DisplayPort is not supported by the RadeonHD driver.
Do you think the DisplayPort integration is on a to-do-list somewhere?
I saw the exact same reviews on Amazon.Assuming that connecting a DVI monitor to the graphics card works fine, this is 100% the converter's fault.
You are right.
- Hans
It's on the to-do list, but down the bottom. For starters, I don't even have a DisplayPort (DP) capable monitor, although that isn't a show-stopper. The real reason for its low priority is that DVI/HDMI/VGA covers almost every monitor available, so we're better off focusing our effort on other features (e.g., 3D). Apple is the only manufacturer that I'm aware of that produces DP only monitors.cdegraeve wrote:First of all, thanks for your reply.Sorry, but DisplayPort is not supported by the RadeonHD driver.
Hans
Hello Hans, any news on DisplayPort support ?Hans wrote:It's on the to-do list, but down the bottom. For starters, I don't even have a DisplayPort (DP) capable monitor, although that isn't a show-stopper. The real reason for its low priority is that DVI/HDMI/VGA covers almost every monitor available, so we're better off focusing our effort on other features (e.g., 3D). Apple is the only manufacturer that I'm aware of that produces DP only monitors.cdegraeve wrote:First of all, thanks for your reply.Sorry, but DisplayPort is not supported by the RadeonHD driver.
Hans
I'm asking this because DVI for my Samsung 4K-monitor, but it only does 30Hz @3840x2160 or does a DVI Duallink cable does 60Hz (?) anyone ?
I am using a DVI-DL cable (and DVI-DL KVM) to display 2560×1600 from my Radeon HD 5450 on my 30" Dell. This is at 50 Hz. But I'm pretty sure you do at least need the DL cable. When I used regular DVI, I could not get more than 1920×1200@50Hz.Benny wrote:I'm asking this because DVI for my Samsung 4K-monitor, but it only does 30Hz @3840x2160 or does a DVI Duallink cable does 60Hz (?) anyone ?
P.S. 3840×2160, huh? Seems I've been beaten on resolution ... but not on real size
