Hi, i bought myself today a 2TB external Seagate USB 3.0 harddrive, that is also USB 2 compatible. It's not formatted yet.
How do i get it formatted in AmigaOS 4.1?
UPDATE: This is now solved easily by pressing Ctrl Alt and M at the same time, to access the Mass Storage program, which allows you to easily format the USB HDD.
External Seagate 2TB USB HDD in AmigaOne 500? (SOLVED!)
Helge Kvalheim, Norway
Re: External Seagate 2TB USB HDD in AmigaOne 500?
Connect the drive to a USB port and Press Control-ALT-M to get the USB MassStorage commodity.
You should get options to set the files system and fomat the drive from here.
HKvalhe wrote:Hi, i bought myself today a 2TB external Seagate USB 3.0 harddrive, that is also USB 2 compatible. It's not formatted yet.
That solved the problem! Never thought of that! THANK you so much for the help, Spectre660! Now i know what to do the next time i should format a USB HDDSpectre660 wrote:Connect the drive to a USB port and Press Control-ALT-M to get the USB MassStorage commodity.
Thanks in advance!
Its is quite a slick little tool.
HKvalhe wrote:That solved the problem! Never thought of that! THANK you so much for the help, Spectre660! Now i know what to do the next time i should format a USB HDDSpectre660 wrote:Connect the drive to a USB port and Press Control-ALT-M to get the USB MassStorage commodity.
How do i get it formatted in AmigaOS 4.1?I'm so happy!
Thanks in advance!
[quote="Spectre660"]Its is quite a slick little tool.
Indeed it is
Thanks again
Indeed it is
