Best set up for Audio Recording + MP3
gerograph
Post by gerograph »
Hi all,
What is the best set up in order to record my old tapes and convert them to MP3? Using onboard audio?
regards Gero
Re: Best set up for Audio Recording + MP3
@gerograph
I suggest you read the topic "HDAudio driver for X1000 onboard sound ". Some people have problems with setting the recording volume but the problem is being worked on. If you are transcribing old tapes, you might want to record uncompressed audio so you can filter tape hiss before you convert to MP3.
gerograph
Post by gerograph »
@xenic
And what would be the best software to do that? Do I need separate software for recording, filtering and converting?
davebraco
Post by davebraco »
zappa2009
Post by zappa2009 »
I updated to the latest HD-Audio-Driver Version 6.20 (I got it yesterday via AmiUpdate).
The AHI-Bug is gone. ;)
LyleHaze
Post by LyleHaze »
zappa2009 wrote:I updated to the latest HD-Audio-Driver Version 6.20 (I got it yesterday via AmiUpdate).
When recording audio, positive feedback is usually a bad thing.
I'll take this comment as the exception.
Nice to hear about improvements.
zappa2009
Post by zappa2009 »
@Lyle
Hehe Thanks but ans Question: When came a Mixer for the HD-Audio ? Without i can`t listen when I record.
LyleHaze
Post by LyleHaze »
zappa2009 wrote:@Lyle
The HDAudio chip in the X1000 does not offer audio monitor abilities. Since HDAudio is the "new standard" I suspect that most or all of the new sound chips will not.
I am working on a software solution (one of many projects in front of me), but it will not be through the Mixer.
Once it is working and tested, I'll be sure to make it available.
zappa2009
Post by zappa2009 »
Good to hear ;)
BTW , If I use HD-Rec ( www.hd-rec.de ) I can hear some monitor sounds with HD-Audio. But with some Delay Echo and Ripple. If it helps for future work.
AlexC
Post by AlexC »
BTW , If I use HD-Rec ( http://www.hd-rec.de ) I can hear some monitor sounds with HD-Audio. But with some Delay Echo and Ripple. If it helps for future work.
HD-Rec takes care of copying the input(s) to the output via its own software mixer.
There shouldn't be much of a delay, not enough to be noticeable, unless the buffers are very large or something is really slow in the I/O chain of events.
At least that was my experience with some older HD-Rec on the A1-XE several years ago, but after some HD-Rec and OS updates it stopped working altogether for me and I haven't tried it again since. What version of HD-Rec are you using?
