Hello Guys,
I have muiowb 1.9 installed on my sam 460ex, now I have noticed a problem, basically when I try to download a file from os4depot or aminet or other sites, the window opens but the download does not start any file downloads.
I reinstalled the program but the problem persists.
muiowb 1.9 doesent download
Re: muiowb 1.9 doesent download
Have you set a downlod path in the settings?toolkitman wrote:Hello Guys,
Yes but it doesent works.
One possibility... are you running MuiOWB on its own screen? Up to a very recent MUI update, MuiOWB couldn't open file requestors on its own screen.However, the screen with the requestor (usually WB) wouldn't always jump to front.
i'm running it in workbench.
Thank you Daveyw,
you are right, i have tried using muiowb in a mui screen and now it download. I remember now that some days ago i have installed a system update for mui.
Is this a bug of the new mui update?
Happens to me, too, now and then with MUIOWB 1.9, with this updated system files for MUI. It would seems that it has reproduced a minor bug, or remain a limitation, due to the fact that we don't have MUI 4 yet.
So to understand, the Download requester gets problem to download files. Sometimes, it manages to download, but with larger files, this can suddenly stop and appear to do nothing.
I hope this bug can be fixed...
Helge Kvalheim, Norway
Someone else reported getting this same problem:
http://www.amigans.net/modules/xforum/v ... mpost81818
I think that is the best place to continue this topic. Locking.ChrisH wrote:Someone else reported getting this same problem:
