SuperTuxKart 0.8 Linux-PPC bugfix release
A bugfix release of SuperTuxKart 0.8 is available. :)
1. The issue with the wrong colors has been solved.
2. Added AltiVec support
Download: supertuxkart-0.8-altivec-linux-glibc2.13-ppc.tar.bz2
Note: You need Kernel 3.8.7 or higher.
Have a lot of fun with the bugfix release!
Re: SuperTuxKart 0.8 Linux-PPC bugfix release
Post by zzd10h »
As said in your thread on AW.net,
I had problem with this version at start
bin/supertuxkart: error while loading shared libraries: libcurl.so.4: cannot open shared object file: No such file or directory
No problem with the previous version on the same system MintPPC 11.
I made a "sudo apt-get install libcurl4-openssl-dev" and it solves the issue.
STK runs very well (except the lack of joystick support) !
And the installation of your last 3.9.0 kernel was very easy.
Thank you
zzd10h wrote:As said in your thread on AW.net,
Thank you
Thank you for your hint. :) :)
I have installed Mesa 9.1.3 (Debian Sid). Unfortunately STK (old package) has wrong colors. But the new package has correct colors.
(259.57 KiB) Downloaded 1236 times
trevordick
A-Eon Technology
A-Eon Technology
Post by trevordick »
Can you please supply a new download link for SuperTuxKart 0.8 for PowerPC Linux.
I would like to try your latest version under the new Live Ubuntu distro.
Many thanks
Trevor
I'm just Breezin'
trevordick
A-Eon Technology
A-Eon Technology
The link provided above evetually worked. Downloaded and plaus fine. :-)
Is this the latest version?
Trevor.
I'm just Breezin'
trevordick wrote:The link provided above evetually worked. Downloaded and plaus fine. :-)
Trevor.
Yes, it is. Is it on the Ubuntu live dvd later?
trevordick
A-Eon Technology
A-Eon Technology
xeno74 wrote:Yes, it is. Is it on the Ubuntu live dvd later?
Yes it plays fine with the Live DVD (installed). It is not currently installed by default. I will check to see is this is possible (assuming you are in agreement).
Also your versions appears better that the version available from the Ubuntu software center, which had a few minor graphic glitches, Your version is fine! :-)
Trevor
I'm just Breezin'
Yes, of course I'm in agreement. It would be very nice to have SuperTuxKart 0.8/AltiVec on the Live DVD.
trevordick
A-Eon Technology
A-Eon Technology
Thanks, it will be added to the release version.
Trevor
I'm just Breezin'
trevordick wrote:Thanks, it will be added to the release version.
Trevor
Thank you!
