Changing the way Workbench draws icons during drag&drop
ZeroG
Post by ZeroG »
If you drag&drop a lot of files around on the Workbench the system gets very, very slow because the bitmap showing the selected icons gets too big for the graphicscard (i use a Radeon 9200).
I think it would be a good idea to change the way Workbench draws icons during drag&drop to something like this:
  • 1-10 objects: use the old drawing method.
  • more than 10 objects: just show a placeholder icon and the total number of files/drawers selected
Hypex
Re: Changing the way Workbench draws icons during drag&drop
Post by Hypex »
That is a good idea as it can be hard to see where it is going as well! Making sure that red pointer is over that drawer. ;-)
Amigo1
Post by Amigo1 »
ZeroG wrote:If you drag&drop a lot of files around on the Workbench the system gets very, very slow because the bitmap showing the selected icons gets too big for the graphicscard (i use a Radeon 9200).
a very good idea!
Steady
Post by Steady »
I agree. I think that would be a good option.
Spektro
Post by Spektro »
Thanks ZeroG! I've entered your request to the AOS4 BZ database: ID 8437.
- Janne Peräaho
