Which Uboot version are you using?
Since some Uboot updates are only "one-way" I wonder which Uboot version on SAMs are you using. For example I'm still running 1.3.1a but this is more lack of time result than anything else.
Re: Which Uboot version are you using?
Given ACube are still actively supporting UBoot on their boards I don't see any problem with updating.alekc wrote:Since some Uboot updates are only "one-way" I wonder which Uboot version on SAMs are you using. For example I'm still running 1.3.1a but this is more lack of time result than anything else.
ACube provides awesome tech support - some a lot larger companies should be learning from them actually. From my perspective the only reason I'm still running old version of UBoot is just a problem of finding those 10 minutes to download file, burn CD and put it into SAM drive (and finding those 10 minutes when I'm at home with access to SAM). Out of curiosity I was wondering if there are more people running older versions of Uboot. This can be helpful in future FAQ updates and betatesting I guess.ssolie wrote:Given ACube are still actively supporting UBoot on their boards I don't see any problem with updating.alekc wrote:Since some Uboot updates are only "one-way" I wonder which Uboot version on SAMs are you using. For example I'm still running 1.3.1a but this is more lack of time result than anything else.
- Hans-Joerg Frieden
U-Boot is the firmware, and is neither done by Hyperion, nor is it related to AmigaOS. Inquiries about it should either be directed at ACube directly, or discussed on general forum. Please limit the discussion here to purely AmigaOS related issues.
Thank you
Thank you
