Whats the official situation on command line means to Reboot or Power Down any* AmigaOS machine?
Why are some going to the effort of writing tools like Poff?
If there is a catch all way to do either of these please point me how to do this.
* this is the keyword!
Thank you.
Reboot and Power Off
Re: Reboot and Power Off
It seems just the X1000 and 460ex can do it out of the box.
The older 440-Series can´t do it until a sophisticated update-procedure of the onboard-fpga is done so a-cube told me.
For the legacy NC-Amigas (uA1..etc) i don´t know if they support it generally.
But Yes, it should also be added to the Pulldown-Menu of the Workbench "Switch off" or similar Menu-Point.
- salass00
Pegasos 2 machines can also be s/w powered down by using openfirmware.resource calls as done by pegoff.fingus wrote:It seems just the X1000 and 460ex can do it out of the box.
- salass00
Because such tools take only some minutes to write and work well as a stopgap until an official solution comes along?djrikki wrote:Why are some going to the effort of writing tools like Poff?
FWIW I released the code of my sam460off test program a while back which helped the development of at least the "poff" tool so I guess I'm partly to blame
An official solution is being worked on but I won't say anything more on that...
A system supported shutdown mechanism is being worked on and will be made available when it's done.djrikki wrote:Whats the official situation on command line means to Reboot or Power Down any* AmigaOS machine?
See above.djrikki wrote:Why are some going to the effort of writing tools like Poff?
Locking as I don't see any point in discussing this further.
