Listbrowser AutoVirtualWidth Bug
tbreeden
Post by tbreeden »
With AOS 4.1 upd 6, ListBrowser.gadget 53.52,
the LISTBROWSER_AutoVirtualWidth tag does not seem to work if
the list has fixed width columns.
The horizontal scroller scrolls well past the end of the columns and
begins re-displaying part of the first columns.
Explicitly using LISTBROWSER_VirtualWidth set to ncols*<staticwidth>
seems to work, as does just using LISTBROWSER_AutoWidth.
This is the same thing reported about a year ago in
"problem with horizontal slider in listbrowser-gadget
http://forum.hyperion-entertainment.biz ... =26&t=1144
No followup appears, beyond not using fixed size columns.
Is it on the bug list?
Tom
Rigo
Re: Listbrowser AutoVirtualWidth Bug
Post by Rigo »
Somehow I managed to miss the original thread, so it's the first I've heard about it. I'll look into this.
Simon
mritter0
Post by mritter0 »
This issue still exists. Is there going to be a fix for it any time soon?
salass00
Post by salass00 »
mritter0 wrote:This issue still exists. Is there going to be a fix for it any time soon?
I just found the cause of the problem after a lot of debugging and fixed it.
