as known the last AOS 4.1.6 doesn't support the PCI-e 1x port of the sam460 with full I/O.
Is there a date for a new Kernel Update which support the port as a normal port with full I/O ? Last info from dec 2012 say's soon
btw. is it normal that also uboot doesn't see the PCI-e card in the 1x slot with the command "pci" ?
i see only my Raid-Controller and the VGA card. Nothing from the PCI-e 1x slot - try a WLAN card and a GeForce graphics card ? both doesn't shown under uboot with the "pci" and with Ranger under AOS 4.1.6.
Please advise...
Many thanks Godfather
