Nightlong game
electric-magic
Nightlong game
Post by electric-magic »
Bought this last week.
Anyone got this to work on the x1000.
Reading other forums seems to be problems with graphics on other machines.
Will try to install it tonight.
Ax1000/A4000 040 D/A1200 030
electric-magic
Re: Nightlong game
Installed the game.
It works except for some graphic problems when the main character moves.
I read that if you turn compositing off it should improve it. Anyone know how you do this.
All the video cut screens work.
Slayer
Re: Nightlong game
Post by Slayer »
double click Prefs drawer
double click GUI icon
select Effects Subsystem entry
untick Enable box below Compositing effects
Save
select Menus Subsystem entry
check ticked entry boxes below Appearance properties
(not sure how much if any of these options are relevant)
Save
Soft/cold reboot just to be sure
see how you go
Re: Nightlong game
Slayer wrote:double click Prefs drawer
Save
Save
see how you go
IIRC you also had to run the game on a 16bit screen to get rid of the "heatwave" effect that came along now and then.
But this was with upd 2 or 3 and i haven't tried it since
electric-magic
Re: Nightlong game
I am running now in 16bit and compositing off but no difference, still poor graphics on the main character.
Thanks for your input.
