amigainput prefs 53.10 missing feature
lazi
Post by lazi »
There is a joypad with a digital top hat switch as it shown below.
When this device is assigned to a lowlevel.library gamepad or joystick the top hat switch is not shown in the directional remapping cycle gadget.
This would be the natural selection for digital control remapping.
The cycle gadget and maybe amigainput itself lets only remap x/y and z axis for direction.
Re: amigainput prefs 53.10 missing feature
I quite often see the Z-axis and Z-axis rotation sliders appear. I have a joypad here currently and the right-hand thumbstick seems to somehow be mapped to them (how the sliders move makes little sense). Shouldn't the right-hand stick show up the same as the left-hand stick - ie. with a X-axis/Y-axis analog control?
lazi
Post by lazi »
@chris:
I don't get the difference here, because the controller seems to have two identical analog sticks. However that Z axis/rotate works well if you calibrated and you can even remap that to lowlevel.library which is not true for the hat switch.
lazi wrote:@chris:
It doesn't calibrate Z-axis in any meaningful way though, so I think this is a bug. The hat comes up here too, although AmigaInput crashed before I got far enough to investigate what it actually mapped to on the controller.
lazi
Post by lazi »
@chris:
Maybe you should post that crashlog somewhere. I think it is important to have a robust and functional amigainput.library.
