The "Choose a lowlevel.library port" cycle gadget at the lowlevel tab has an empty item if you roll it clicking the loop arrow.
It is allowed to assign a device to this unit which reveals that is is joystick unit 3. Normally you can't select this unit from the gadget.
amigainput prefs 53.10 bug
Re: amigainput prefs 53.10 bug
Yep confirmed, as i was here i did a quick grab
BZ #8389 created
