Qemu
Qemu
Booting Windows2000 sp4 Explore 6 in fullscreen from Aqemu on Debian on my X1000
Its a little bit slow but office 97 running fine.
Missing getting usb to work, but think it's a question of rights on Debian. I've got a simple network to function and
cdrom works.
(48.26 KiB) Downloaded 1367 times
trevordick
A-Eon Technology
A-Eon Technology
Re: Qemu
Post by trevordick »
Wow
You guys are impressive! :-)
So checking through the message boards so far the following CPU/OS combinations have been emulated under QEMU on the AmigaONE X1000
ARM (Raspberry Pi)/Debian Raspbian
x86/Windows2000 sp4
486/Windows NT 4.0 SP 6
x86/Windows XP SP 2
x86/Windows 98
Have I m1ssed any?
Trevor
I'm just Breezin'
Re: Qemu
trevordick wrote:Wow
x86/Windows2000 sp4
x86/Windows XP SP 2
x86/Windows 98
Have I m1ssed any?
Trevor
I have not completed the installation but booting on a ibm_pc_64/core duo with a mint_mate_64 bit. Have some trouble getting x to run but cpu emulation works.
Aros_live cd on ibmpc_32_bit qemu_32 bit cpu
(273.06 KiB) Downloaded 1321 times
Re: Qemu
Aros with usb working
(43.2 KiB) Downloaded 1265 times
trevordick
A-Eon Technology
A-Eon Technology
Re: Qemu
Impressive. :-)
How usable is AROS under QEMU emulation?
Trevor
I'm just Breezin'
Re: Qemu
trevordick wrote:Impressive. :-)
Trevor
Hi Trevor
The speed of all qemu emulation is poor in relation to run on hardware.
Common to all the emulations is that it is more fun than usable.
However, there are applications where it does not matter so much, for example, word processing.
As an example, OBW on aros is very slow to load but once it is loaded reasonably fast in browsing.
Many menu options are slow to pop up.
I have not tested all funtions in Aros yet.
DOpus run with fine speed .
Usb function but is slow,there may be problems with rights.
Internet Browsing function.
So far, it is everything I know.
trevordick
A-Eon Technology
A-Eon Technology
Re: Qemu
Musa,
Thanks for the information. Keep the screen grabs coming. :-)
Trevor
I'm just Breezin'
Re: Qemu
Kernel 3.11.0 PowerPC works slow but well on QEMU/PPC.
(300.79 KiB) Downloaded 609 times
Re: Qemu
(129.73 KiB) Downloaded 217 times
Re: Qemu
KVM-PR works on my A1-X1000. :-)
Support running guest kernels in virtual machines on processors
without using hypervisor mode in the host, by running the
guest in user mode (problem state) and emulating all
privileged instructions and registers.
This is not as fast as using hypervisor mode, but works on
machines where hypervisor mode is not available or not usable,
and can emulate processors that are different from the host
processor, including emulating 32-bit processors on a 64-bit
host.
Screenshots:
