Images in Intuition menus
I'd like to be able to add custom images in individual Intuition/GadTools menu items.
This should be possible already, but since nobody can tell me how to do it, I'm assuming it's not actually implemented and therefore should be a feature request. (my previous thread with futile attempts to get this to work: http://forum.hyperion-entertainment.biz ... ?f=26&t=94)
salass00
Re: Images in Intuition menus
Post by salass00 »
@chris
I just tried your code on my beta system and as you say it crashes on the LayoutMenus() call. I'll look into this and see if it's something that I can fix.
Edit:
Just found the problem. The bug was in CreateMenus() in the code that's supposed to check if the provided image is a BOOPSI image (non-BOOPSI images are copied to an internal buffer in CreateMenus()). Easy to fix once I saw it.
salass00 wrote:@chris
Edit:
Thank you! This thread can be closed since it was actually a real bug.
