AmiUpdate (version 2.32) does not seem to be able to find the new HD Audio driver for my X1000. The last three updates it pulled were the new X1Ktemp dockie, and a mixer and codesets update. (Note I do not run Mixer in any of my startup sequences). I have these installed just fine.
Is there another method for getting this driver? I'm using only the amiupdate.net server
AmiUpdate does not get HD Audio driver [solved]
Pocasset, Massachusetts USA
- salass00
Re: AmiUpdate does not get HD Audio driver
If so, then that's your problem. The www.amiupdate.net server is only for updates to 3rd party components. For official OS updates you need the update.amigaos.net server configured and active in AmiUpdate prefs.Nagasakee wrote: I'm using only the amiupdate.net server
that did it! Thanks. Now I need to ask how to delete an embarrassing thread...
I see nothing embarrassing about it, AmiUpdate has confussed most of us at times. This thread could help others with the same problem.Nagasakee wrote:that did it! Thanks. Now I need to ask how to delete an embarrassing thread...
Ken
What you should do instead of deleting the thread is add [SOLVED] or similar to the subject field of your first post.
Re: AmiUpdate does not get HD Audio driver [solved]
Helped me out! Thanks
I had no idea you had to add the amigaos.net server.
Wow! A lot of updates now!
Sam
Sam
Can we just get something straight here, it's not AmiUpdate that confused you, simply the use of different servers
AmiUpdate was designed from the very start to have the ability to work with multiple servers with files hosted at various different locations. This is explained in the documentation, and the intended behaviour is that different servers offer different updates. That is where we are now, the server at "www.amiupdate.net" is the third party application database, then we have the SDK database, and now, more recently, we have the server at update.amigaos.net offering OS updates only.
These servers have been well publicized in the past along with their usage. If anyone is finding it hard to keep up, then by all means let us know, and something can be added to the website in order to try and clarify things.
This is not a personal attack, before anyone gets the wrong end of the stick, it is merely an attempt to try and gauge whether clarification is really required or not. Although, with that said, it should be noted that it isn't really the place for AmiUpdate to clarify what servers are available or not, as this can change without notice at any time. AmiUpdate is a software product that will work with external resources which are out of the control of the AmiUpdate maintainers.
Simon
Simon
I think AmiUpdate does a fantastic job. I do think it needs perhaps clarifying as to what servers are available however as other than looking through here I wouldn't have known about the OS update server. Perhaps a good idea would be to have AmiUpdate show you a list of all available servers with descriptions as to what they update and then the user has the option of switching them on or off as desired. I am not sure what the process is to set up a new AmiUpdate compliant server but I take it it would have to be authorised by AmiUpdate to ensure that it is not malicious. At this point it could be added to a master server list that AmiUpdate downloads so that users are aware of changes/new servers and what they do.
You say there are 3 servers at the moment? One for thrid party apps, one for the OS and one for the SDK. What is the SDK server update address?
But don't misunderstand - AmiUpdate is a brilliant tool - very impressed as to how well it handles complex updates
Sam wrote: You say there are 3 servers at the moment? One for thrid party apps, one for the OS and one for the SDK. What is the SDK server update address?
www.amiupdate.net/SdkServer
Thanks Raziel. Sorry for the late post.
