Use of DrawImageState
abalaban
Post by abalaban »
I'm willing to draw an image from AISS into a rastport. To do so I've created a Bitmap_ic object with the following code
IIntuition->NewObject(pCtx->BitmapClass, NULL,
    BITMAP_SourceFile, "TBImages:list_ledred_s",
    BITMAP_DisabledSourceFile, "TBImages:list_ledred",
    BITMAP_Screen, pCtxt->Screen,
    BITMAP_Masking, TRUE,
TAG_END);
This call returns a non null object thus I'm assuming the call succeeded.
Then I'm trying to do
IIntuition->DrawImageState(pCtxt->rp, (struct Image*)pCtxt->ledImage, 10, 10, IDS_NORMAL, pCtxt->dri);
Unfortunately nothing is displayed. Am I wrongly using DrawImageState? Am I wrongly assuming the NewObject call succeeded? Anything else?
AmigaOne XE/G4
Re: Use of DrawImageState
Post by thomasrapp »
These two statements should work as expected, given that all variables contain the values which their names let believe. Like so often there is by far not enough code to see a mistake.
abalaban
Post by abalaban »
Thank you Thomas for your answer.
I'm trying to write a Docky which should display a led on or off.
Upon reception of DOCKYSET_Screen I'm executing the following statements:
pCtxt->Screen = (struct Screen*)msgData;
pCtxt->dri = IIntuition->GetScreenDrawInfo(pCtxt->Screen);
pCtxt->ledImage = IIntuition->NewObject(pCtxt->BitmapClass, NULL,
TAG_END);
Note that pCtxt->BitmapClass is obtained at docky initialization by the following
pCtxt->BitmapClassLib = IIntuition->OpenClass("images/bitmap.image", 52, &(pCtxt->BitmapClass);
Then upon DOCKYSET_RedrawNow I'm doing:
IGraphics->Move(pCtxt->rp, 10,10);
IIntuition->DrawImageState(pCtxt->rp, (struct Image*)pCtxt->ledImage, 0, 0, pCtxt->Activated?IDS_NORMAL:IDS_DISABLED, pCtxt->dri);
EDIT: Okay the problem was caused by the 'BITMAP_Masking', if I remove it everything works as expected. Now I'm trying to figure out how I can draw this bitmap without seeing this dark background... Probably something to do with the DOCKYGET_RenderMode but as soon as I put something different from DOCKYRENDERMODE_RPPA the AmiDock refuses to load it :?:
AmigaOne XE/G4
LyleHaze
Post by LyleHaze »
I have never played down at the Dockys, but I use LEDs a lot in some of my other projects..
In a recent project I load a 3 state red LED
myled = IIntuition->NewObject(
BitmapClass, NULL,
BITMAP_Transparent, TRUE,
BITMAP_Screen, scrn,
BITMAP_SourceFile, "tbimages:list_ledred_h", // one note
BITMAP_SelectSourceFile, "tbimages:list_ledred_s", // multinote
BITMAP_DisabledSourceFile, "tbimages:list_ledred", // no notes
TAG_END);
This works well with the following
rp,
(struct Image *)myled,
LeftEdge,
TopEdge,
draw_state,
di);
As Thomas pointed out, the devil may be in the details not shown.
This assumes that BitmapClass has been opened,
Draw_state is a value from 0 to 2,
rp is a nice RastPort to draw into, and
di is the result of a successful GetScreenDrawInfo(screen).
abalaban
Post by abalaban »
@Lyle,
thank you for your answer, I was probably editing my message when you were redacting your.
I think the problem may be caused by the Docky environment and the fact I was requesting a BITMAP_Masking. I'm investigating if it's not related to the DOCKYRENDERMODE_RPPA render mode.
AmigaOne XE/G4
