Problems booting from external USB SDcard reader [Solved]
I have a problem booting OS4.1 on A Sam 440ep-flex from an SDcard in an external USB SDcard reader.
The SD card is recognized as a bootlable drive by UBoot and will load the Kickstart files from it.
After this OS4.1 loads from the hard drive instead of the SDcard. I have noted that the SD card does not
appear at all in the devices in the Early startup menu.
The SD card reader is a combo SDCard and Sim card reader and the SDcard shows up in OS 4.1 update2 once it boots for the hard drive.
I am able to boot OS4.1 from an identically configured flash drive in the same usb port and the flash drive
shows up as a bootable device in the early startup menu.
Slayer
Re: Problems booting from external USB SDcard reader
Post by Slayer »
Have you tried using NVSetVar boot1 [To your device abbreviation]
It's probably something I'd try to do given the circumstances ;)
It'll probably set it fine (since I don't think NVSetVar really cares what you want to define) but whether or not it is properly recognised is another thing altogether
Uboot settings
scan_usb_storage=1
boot1=usb
boot2=s4siicdrom
boot3=s4sii
As I have said a usb flashdrive boots ok and acts as expected. the SDcard in the reader does not
USB Log from bootup and then SDcard reader is attached.
Hidden Text - Click to Show :
I: [06:42:35] USB stack | | ==========
I: [06:42:35] USB stack | | USB System Software Task started
I: [06:42:35] USB stack | | Starting HCDs...
I: [06:42:35] USB stack | | ...HCDs started.
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FF8FDC0 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07010 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE071F0 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FF8FDC0 initialized
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07010 initialized
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE071F0 initialized
I: [06:42:35] hub.usbfd | HUB | All ports are empty
I: [06:42:35] hub.usbfd | HUB | Device found on port 1 of hub "Front Roothub (ohci.usbhcd/1)".
I: [06:42:35] hub.usbfd | Hub port | Device at port 1 of hub "Front Roothub (ohci.usbhcd/1)" is full-speed.
I: [06:42:35] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [06:42:35] hub.usbfd | HUB | Driver Running
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE076F0 is {Vendor: 0xE305, Product: 0x0806, Class: 09.00}
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE076F0 initialized
I: [06:42:35] hub.usbfd | HUB | Device found on port 1 of hub "Rear Roothub (ohci.usbhcd/0)".
I: [06:42:35] hub.usbfd | Hub port | Device at port 1 of hub "Rear Roothub (ohci.usbhcd/0)" is full-speed.
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07970 is {Vendor: 0x8F05, Product: 0x6663, Class: 00.00}
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07970 initialized
E: [06:42:35] MassStorage Device Task | Massstorage | Lun 0 has device type 0x00 (Direct access) and is removable
I: [06:42:35] hub.usbfd | HUB | Device found on port 1 of hub "USB2.0 Hub".
I: [06:42:35] hub.usbfd | Hub port | Device at port 1 of hub "USB2.0 Hub" is low-speed.
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07C90 is {Vendor: 0xB404, Product: 0x8180, Class: 00.00}
I: [06:42:35] hub.usbfd | HUB | Device found on port 2 of hub "USB2.0 Hub".
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07C90 initialized
I: [06:42:35] hub.usbfd | Hub port | Device at port 2 of hub "USB2.0 Hub" is low-speed.
I: [06:42:35] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07F10 is {Vendor: 0x0B04, Product: 0x3365, Class: 00.00}
I: [06:42:35] USB Fkt Init | Init Fkt | Fkt 0x5FE07F10 initialized
I: [06:42:35] MassStorage Device Task | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [06:42:35] USB stack Process | | USB System Software Process started.
I: [06:42:35] USB stack Process | | Reading FD descriptors...
I: [06:42:35] USB stack Process | | FD infos read
I: [06:42:35] USB stack Process | Rebind FD | Weak FD for Ifc 0x5FE09140 is being preempted.
I: [06:42:35] USB stack Process | Rebind FD | Weak FD for Ifc 0x5FE091C0 is being preempted.
I: [06:42:35] USB stack Process | | Starting HCDs...
I: [06:42:35] USB stack Process | | ...HCDs started.
I: [06:42:35] USB stack Process | | USB stack fullbooted
I: [06:42:35] USB FD fkt start | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [06:49:28] hub.usbfd | HUB | Device found on port 2 of hub "Additional Roothub (ohci.usbhcd".
I: [06:49:28] hub.usbfd | Hub port | Device at port 2 of hub "Additional Roothub (ohci.usbhcd" is full-speed.
I: [06:49:28] USB stack | New Fkt | HCD failed to add/create Fkt
W: [06:49:28] hub.usbfd | HUB | Retrying attachment on port 2 of hub "Additional Roothub (ohci.usbhcd" (previous attempt failed with error -19)
I: [06:49:28] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [06:49:28] USB Fkt Init | Init Fkt | Fkt 0x5548A820 is {Vendor: 0xE305, Product: 0x0506, Class: 09.00}
I: [06:49:28] USB Fkt Init | Init Fkt | Fkt 0x5548A820 initialized
W: [06:49:28] USB FD fkt start | USBFktGetCfgDescriptors | Error reading config chain from Fkt 0x5548A820
E: [06:49:28] USB FD fkt start | USBFktGetCfgDescriptors | Failed to read config from Fkt 0x5548a820 - error -35
E: [06:49:28] USB FD fkt start | FD launcher | Failed to read CfgDsc
I: [06:49:35] hub.usbfd | HUB | Detaching Function removed from hub port 2
I: [06:49:35] hub.usbfd | HUB | Device found on port 2 of hub "Additional Roothub (ohci.usbhcd".
I: [06:49:35] hub.usbfd | Hub port | Device at port 2 of hub "Additional Roothub (ohci.usbhcd" is full-speed.
I: [06:49:35] USB stack | New Fkt | HCD failed to add/create Fkt
W: [06:49:35] hub.usbfd | HUB | Retrying attachment on port 2 of hub "Additional Roothub (ohci.usbhcd" (previous attempt failed with error -19)
W: [06:49:35] hub.usbfd | HUB | Resetting hub port 2 and trying again
I: [06:49:35] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [06:49:35] USB Fkt Init | Init Fkt | Fkt 0x5548A8C0 is {Vendor: 0xE305, Product: 0x0506, Class: 09.00}
I: [06:49:35] USB Fkt Init | Init Fkt | Fkt 0x5548A8C0 initialized
E: [06:49:36] hub.usbfd | HUB | Port 4 powering failed
I: [06:49:36] hub.usbfd | HUB | One or more hub ports were unable to power up.
I: [06:49:36] hub.usbfd | HUB | All ports are empty
I: [06:49:36] hub.usbfd | HUB | Status Change Pipe error -35
I: [06:49:40] hub.usbfd | HUB | Detaching Function removed from hub port 2
I: [06:49:40] hub.usbfd | HUB | Device found on port 2 of hub "Additional Roothub (ohci.usbhcd".
I: [06:49:40] hub.usbfd | Hub port | Device at port 2 of hub "Additional Roothub (ohci.usbhcd" is full-speed.
I: [06:49:40] USB stack | New Fkt | HCD failed to add/create Fkt
W: [06:49:40] hub.usbfd | HUB | Retrying attachment on port 2 of hub "Additional Roothub (ohci.usbhcd" (previous attempt failed with error -19)
W: [06:49:40] hub.usbfd | HUB | Resetting hub port 2 and trying again
W: [06:49:40] hub.usbfd | HUB | Hub port 2 attachment was not possible
E: [06:49:40] hub.usbfd | HUB | Failed to add device attached to hub port 2 due to error -19
I: [06:49:40] hub.usbfd | HUB | Hub driver was unable to
add the attached device.
I: [06:49:40] hub.usbfd | HUB | Port 2 of hub "Additional Roothub (ohci.usbhcd" disabled - port is empty.
I: [06:49:40] hub.usbfd | HUB | Device found on port 2 of hub "Front Roothub (ohci.usbhcd/1)".
I: [06:49:40] hub.usbfd | Hub port | Device at port 2 of hub "Front Roothub (ohci.usbhcd/1)" is full-speed.
I: [06:49:40] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [06:49:40] USB Fkt Init | Init Fkt | Fkt 0x5548A8C0 is {Vendor: 0xE305, Product: 0x0506, Class: 09.00}
I: [06:49:40] USB Fkt Init | Init Fkt | Fkt 0x5548A8C0 initialized
I: [06:49:40] hub.usbfd | HUB | Device found on port 1 of hub "USB2.0 Hub".
I: [06:49:40] hub.usbfd | Hub port | Device at port 1 of hub "USB2.0 Hub" is full-speed.
I: [06:49:40] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [06:49:40] hub.usbfd | HUB | Device found on port 2 of hub "USB2.0 Hub".
I: [06:49:40] USB Fkt Init | Init Fkt | Fkt 0x5548AAA0 is {Vendor: 0xE305, Product: 0x1107, Class: 00.00}
I: [06:49:40] USB Fkt Init | Init Fkt | Fkt 0x5548AAA0 initialized
E: [06:49:40] MassStorage Device Task | Massstorage | Lun 0 has device type 0x00 (Direct access) and is removable
I: [06:49:40] hub.usbfd | Hub port | Device at port 2 of hub "USB2.0 Hub" is full-speed.
I: [06:49:40] hub.usbfd | HUB | Driver Running
I: [06:49:40] USB Fkt Init | Init Fkt | Fkt 0x5548ADC0 is {Vendor: 0xC511, Product: 0x2105, Class: 00.00}
I: [06:49:40] USB Fkt Init | Init Fkt | Fkt 0x5548ADC0 initialized
Slayer
Post by Slayer »
ok sorry, guess you need something extra or tweaked in DEVS:USB or at least a uboot update and perhaps an associated sii3114ide_conf parameter addition... but enough of my horrible speculation :D
It seems as if there is some kind of usb power reset or something after kickstart loads that caused the drive to be lost until OS 4.1 starts .
Hypex
Post by Hypex »
They must have fixed UBoot for the Sam. When I tried to boot off USB on my A1 it was dog slow. Seemed like 100K a second! :-o It made USB1.1 look extremely fast. :-P
mechanic
Post by mechanic »
Spectre660 wrote:It seems as if there is some kind of usb power reset or something after kickstart loads that caused the drive to be lost until OS 4.1 starts .
There is a 'USBCTRL start' command in the Startup Sequence. I do not have a SDcard.
So the OS stack, logs, and all that stuff is ....er....initialized, transferred at that time.
Anybody....Yes??
sba
Post by sba »
Spectre660 wrote:I have a problem booting OS4.1 on A Sam 440ep-flex from an SDcard in an external USB SDcard reader.
Is the SD card recognized if the system has been properly booted?
Thanks for the nudge.
It works now with a newer external card reader and update 3.
The older card reader seems to give uboot some problems every other boot attempt.
