Uboot error message.
acmn
Post by acmn »
What is the meaning of this error message that Uboot prints in my AO500?
"ERROR: Unknown Sense key 05 ASC 64 ASCQ 00"
It appears if there is an audio cd inserted.
Is there any way to avoid it?
ZeroG
Re: Uboot error message.
Post by ZeroG »
It's just UBoot looking for a bootable CD.
Remove the AudioCD.
acmn
Post by acmn »
Yes, but Uboot prints that line several times. How to avoid that?
It's a little bit annoying.
Do you have a USB hub attached or USB flash drive or SDcard ?
Post by thomasrapp »
acmn wrote:Yes, but Uboot prints that line several times. How to avoid that?
Remove the audio CD.
Spectre660 wrote:Do you have a USB hub attached or USB flash drive or SDcard ?
How is this related to the audio CD messages?
@acmn
Change the Uboot Console setting to silent from verbose in the Uboot Menu.
I like a little background as to the setup that is giving a problem as I try to duplicate it to help find a solution if I am not aware of the issue causing the problem
