An input.device freeze I once caught.
Hypex
Post by Hypex »
Hello. A couple of years back I collected a few crash logs where the input.device froze the system. I don't know if the problem was resolved but I still see input freezes in the system so thought I would post some logs and in case it would help resolve a possibly serious issue. At this point it would be good if a log included the version of the crash logger that generated it as well as system module versions.
This first one has a note: Was opening menu bar with MultiView and right mouse button. Bar changed then system froze.
Hidden Text - Click to Show :
Trap type: DSI exception
Machine State (raw): 0x0000F030
Machine State (verbose): [ExtInt on] [User] [FPU on] [IAT on] [DAT on]
Instruction pointer: in module Kickstart/graphics.library.kmod+0x0002AE34 (0x01348D94)
Crashed task: input.device (0x6FF792A0)
0: 6FF94F00 6FF71B10 5A5BDA1A E000E000 0000005F FFFFFFFF 65CCE260 00000000
8: 0136E2E4 00000000 6FF767AC E000E000 535A9A33 5A585A7A 5A5C4A5A 5A5B1A5A
16: 5A5A1E5A 5A5A5B5A 5A9ADA52 5A9A5A52 5A5A0A4A 5A4A5F5A 00000001 00000000
24: 01C40000 8000000A 01C40000 6FF164D0 6FF76000 E000E000 00000000 6FFB4420
CR: 535A9A35 XER: A0004A5A CTR: 0132B2F4 LR: 0132B39C
DSISR: 40000000 DAR: E000E000
FP0 : FFF8000082002000 3FF0000000000000 3FDD1758E0000000 0000000000000000
FP4 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP8 : 0000000000000000 40EFFFE000000000 4330000000000000 403F000000000000
FP12: 0000000000000000 FFF8000000000000 0000000000000000 0000000000000000
FP16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP24: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP28: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FPSCR: 82002000
DSI verbose error description: Access not found in hash or BAT (page fault)
Access was a load operation
Registers pointing to code:
r8 : native kernel module Kickstart/intuition.library.kmod+0x00021BE4
r24: native kernel module Kickstart/bootmenu.kmod+0x0099FE20
r26: native kernel module Kickstart/bootmenu.kmod+0x0099FE20
ip : native kernel module Kickstart/graphics.library.kmod+0x0002AE34
lr : native kernel module Kickstart/graphics.library.kmod+0x0000D43C
ctr: native kernel module Kickstart/graphics.library.kmod+0x0000D394
Stack Backtrace:
native kernel module Kickstart/intuition.library.kmod+0x00010098
native kernel module Kickstart/intuition.library.kmod+0x00010170
native kernel module Kickstart/intuition.library.kmod+0x000101E8
native kernel module Kickstart/intuition.library.kmod+0x0002C060
native kernel module Kickstart/intuition.library.kmod+0x00030A3C
native kernel module Kickstart/intuition.library.kmod+0x00031954
native kernel module Kickstart/intuition.library.kmod+0x00056AAC
native kernel module Kickstart/intuition.library.kmod+0x00051604
native kernel module Kickstart/intuition.library.kmod+0x00055DBC
native kernel module Kickstart/intuition.library.kmod+0x00058B28
native kernel module Kickstart/intuition.library.kmod+0x00055CA8
native kernel module Kickstart/intuition.library.kmod+0x000538C0
native kernel module Kickstart/intuition.library.kmod+0x0001FAB4
native kernel module Kickstart/intuition.library.kmod+0x0001BCE4
native kernel module Kickstart/intuition.library.kmod+0x0001BDF4
native kernel module Kickstart/intuition.library.kmod+0x0001AE94
native kernel module Kickstart/input.device.kmod+0x0000014C
native kernel module Kickstart/input.device.kmod+0x00001BEC
native kernel module Kickstart/kernel+0x00019C04
Disassembly of crash site:
01348D84: 39200000 li r9,0
01348D88: 4800000C b 0x1348D94
01348D8C: 38630001 addi r3,r3,1
01348D90: 419A0020 beq- cr6,0x1348DB0
>01348D94: 88030000 lbz r0,0(r3)
01348D98: 7F840000 cmpw cr7,r4,r0
01348D9C: 2F000000 cmpwi cr6,r0,0
01348DA0: 409EFFEC bne+ cr7,0x1348D8C
01348DA4: 7C691B78 mr r9,r3
01348DA8: 38630001 addi r3,r3,1
Stack pointer (0x6FF71B10) is inside bounds
Redzone is OK (4)
68k register dump
DATA: 6FF76494 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 6FF76494 6D32F9C4 00000000 00000000 00000000 00000000 00000000 6FF71E60
----> 6D32F9C4 - "CalcKey" Hunk 0001 Offset 000019BC (SegList: 0x1B054C01)
sii0680ide.device 52.1 (09.12.2006)
[sii0680ide/ata_read_drive_properties] unit refused SETFEATURES_XFER(68)
Dump of context at 0xEFFF47A0
Instruction pointer: in module Kickstart/intuition.library.kmod+0x00050408 (0x0199CB08)
Crashed task: input.device (0x6FF692A0)
0: 00000014 6FF51D40 206FCB0E 00000001 6FF51C98 6FF51D48 02092850 02092850
8: FFFFFFFF 0183BAE4 00000000 6FF51D50 35B55133 22900308 0449A010 69249120
16: DE8D71A3 23407F01 87ED4404 21B3AD41 6FF51D78 5DCA29E4 5EE5A38E 00000000
24: 00000000 5F54D95C 590490B8 6FF51DE0 00000000 6FEF64D0 00000000 00000000
CR: 39B55195 XER: C0003F7A CTR: 0183BAE4 LR: 0199CAF4
DSISR: 40000000 DAR: 590490B8
FP0 : FFF8000082068000 40019999A0000000 3FDD1758E0000000 BFF97BBA22082CC0
FP4 : FCFBBFAA6C9AFEFF FF5F6FEEDDFECFFB FE0FDFDD8FDFFCFE 3F13882E50C08463
FP8 : FFFF6BEF6FBEFF9F FF33EBA7E8AFCFF7 6F77CBAE7FFBFCFF 7B5B3FEE77F75EDB
FP12: FFF8000000000001 3EE4F8B588E453C9 EC5BEFF7DAEAFCFB 3C8BBF7DDFDDDDB6
FP16: BE1DFEBBFBEBBDFC B7FFEFBEF5DBFEFF FFFFFFCEFFFBECFF 7F77FBFF9DB7FE39
FP20: BEDFAFAF5EE4EE6F FB5B5F3E35FFFC16 FF5F93FA1FFAFEDD EFB79FD8BED4FDF2
FP24: 7E3FDFFFFDE9EE9B BEDFBFAE9FE2EEFF AF4FF7DFE7DFFDE6 FE1FEFEECFFEFEF3
FP28: FFFBEFEFCFFBD67B FF5B3BAE076DCCFF BE5FEBBE5E63FEFF DF1201C38FFBFEFB
FPSCR: 82068000
r6 : native kernel module Kickstart/kernel+0x00892850
r7 : native kernel module Kickstart/kernel+0x00892850
r9 : native kernel module Kickstart/kernel+0x0003BAE4
ip : native kernel module Kickstart/intuition.library.kmod+0x00050408
lr : native kernel module Kickstart/intuition.library.kmod+0x000503F4
ctr: native kernel module Kickstart/kernel+0x0003BAE4
Stack Backtrace:
native kernel module Kickstart/intuition.library.kmod+0x00050A40
native kernel module Kickstart/intuition.library.kmod+0x00072E04
native kernel module Kickstart/intuition.library.kmod+0x00052F84
native kernel module Kickstart/intuition.library.kmod+0x00053504
0199CAF8: 2B800002 cmplwi cr7,r0,2
0199CAFC: 409D00A4 ble- cr7,0x199CBA0
0199CB00: 2F9A0000 cmpwi cr7,r26,0
0199CB04: 419E0010 beq- cr7,0x199CB14
>0199CB08: 881A0000 lbz r0,0(r26)
0199CB0C: 2F800000 cmpwi cr7,r0,0
0199CB10: 409E0098 bne- cr7,0x199CBA8
0199CB14: A8DB0004 lha r6,4(r27)
0199CB18: 3C000380 lis r0,896
0199CB1C: 3D600380 lis r11,896
Stack pointer (0x6FF51D40) is inside bounds
Redzone is OK (4)
68k register dump
DATA: 00000001 00000067 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 5AEED2D4 5C284004 00000000 00000000 00000000 00000000 00000000 6FF51DA0
Another of the same age. The format is different:
Dump of context at 0x01678EE0
Temporary stack trace:
#0: in module Kickstart/intuition.library.kmod+0x0006F900 (0x013AD9C0)
#1: in module Kickstart/intuition.library.kmod+0x00071F94 (0x013B0054)
#2: in module Kickstart/intuition.library.kmod+0x00052F08 (0x01390FC8)
#3: in module Kickstart/intuition.library.kmod+0x00053504 (0x013915C4)
#4: in module Kickstart/intuition.library.kmod+0x0001FAB4 (0x0135DB74)
#5: in module Kickstart/intuition.library.kmod+0x0001FBAC (0x0135DC6C)
#6: in module Kickstart/intuition.library.kmod+0x00050220 (0x0138E2E0)
#7: in module Kickstart/intuition.library.kmod+0x00051520 (0x0138F5E0)
#8: in module Kickstart/intuition.library.kmod+0x0001F630 (0x0135D6F0)
#9: in module Kickstart/intuition.library.kmod+0x000534D4 (0x01391594)
#10: in module Kickstart/intuition.library.kmod+0x0001FAB4 (0x0135DB74)
#11: in module Kickstart/intuition.library.kmod+0x0001FBAC (0x0135DC6C)
#12: in module Kickstart/intuition.library.kmod+0x0001FC9C (0x0135DD5C)
#13: in module Kickstart/intuition.library.kmod+0x000501A0 (0x0138E260)
#14: in module Kickstart/intuition.library.kmod+0x0001D45C (0x0135B51C)
#15: in module Kickstart/intuition.library.kmod+0x0001BCDC (0x01359D9C)
#16: in module Kickstart/intuition.library.kmod+0x0001BDF4 (0x01359EB4)
#17: in module Kickstart/intuition.library.kmod+0x0001AE94 (0x01358F54)
#18: in module Kickstart/input.device.kmod+0x0000014C (0x0133BD0C)
#19: in module Kickstart/input.device.kmod+0x00001A14 (0x0133D5D4)
#20: in module Kickstart/kernel+0x00019624 (0x01219624)
Crashed task: input.device (0x6FF71240)
0: 00000003 6FF69A10 5A5A5A8A 6AA5653C 6FF69B58 00000000 00000001 00000003
8: 6FF69A78 00000001 000076C0 00000000 48444282 520ED89A 6AA5444E 6FF69A70
16: 69D93ADC 6AA56752 69D718F8 00000000 000002F3 6FF69BE0 2C21322F 6AA569BC
24: 6FF124D0 6FF69B58 00000001 00002000 00000000 00000000 6FEC4010 6FF69BD8
CR: 28444284 XER: 4000587A CTR: 013B3A64 LR: 013AE1CC
DSISR: 40000000 DAR: 69D93ADC
ip : native kernel module Kickstart/intuition.library.kmod+0x0006F900
lr : native kernel module Kickstart/intuition.library.kmod+0x0007010C
ctr: native kernel module Kickstart/intuition.library.kmod+0x000759A4
Stack Backtrace:
native kernel module Kickstart/intuition.library.kmod+0x00071F94
native kernel module Kickstart/intuition.library.kmod+0x00052F08
native kernel module Kickstart/intuition.library.kmod+0x0001FBAC
native kernel module Kickstart/intuition.library.kmod+0x00050220
native kernel module Kickstart/intuition.library.kmod+0x00051520
native kernel module Kickstart/intuition.library.kmod+0x0001F630
native kernel module Kickstart/intuition.library.kmod+0x000534D4
native kernel module Kickstart/intuition.library.kmod+0x0001FC9C
native kernel module Kickstart/intuition.library.kmod+0x000501A0
native kernel module Kickstart/intuition.library.kmod+0x0001D45C
native kernel module Kickstart/intuition.library.kmod+0x0001BCDC
native kernel module Kickstart/input.device.kmod+0x00001A14
native kernel module Kickstart/kernel+0x00019624
013AD9B0: 2F9D0000 cmpwi cr7,r29,0
013AD9B4: 409EFFE0 bne+ cr7,0x13AD994
013AD9B8: 2F900000 cmpwi cr7,r16,0
013AD9BC: 419E0010 beq- cr7,0x13AD9CC
>013AD9C0: 88100000 lbz r0,0(r16)
013AD9C4: 2F800000 cmpwi cr7,r0,0
013AD9C8: 409E0A70 bne- cr7,0x13AE438
013AD9CC: 813810A8 lwz r9,4264(r24)
013AD9D0: 7D234B78 mr r3,r9
013AD9D4: 81290190 lwz r9,400(r9)
Stack pointer (0x6FF69A10) is inside bounds
Redzone is OK (4)
68k register dump
DATA: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 6FF12FB4 6FF69C08 00000000 00000000 00000000 00000000 00000000 6FF699F0
Instruction pointer: in module Kickstart/intuition.library.kmod+0x0006F900 (0x019BC000)
0: 019BC80C 6FF51C30 206FCB0E 00000000 572C8E94 6FF51C90 00000001 00000003
8: 6FF51C98 00000001 000078E0 00000000 59555193 22900308 5C6671E6 6FF51C90
16: 5C806D0C 5AD8E4CA 556AD218 00000000 00000158 6FF51E00 2821322F 5AD8E5C4
24: 6FEF64D0 6FF51D78 00000001 00002000 00000000 00000000 6FEA8010 6FF51DF8
CR: 39555195 XER: C0003F7A CTR: 019C20A4 LR: 019BC80C
DSISR: 40000000 DAR: 5C806D0C
FP0 : FFF8000082004000 3FE7D00000000000 4330000000000000 4330000000000000
FP4 : BE68363628800000 BE0B1B1B130F0900 3ED0306C6C510000 0000000000000000
FP8 : BDD85C31984468FB BF5D432CFE4F8FA9 4024000000000000 3D1F5F4000000000
FP12: 4074C00000000000 40D17B0000000000 AC5BEBB5DAE0F8DA 1C8947ACC7CE6E5A
FP16: B80B3D77F7537BF8 B0AFEFAAD119D27F 7BF77BCEFF7AEC7F 7D77BBDF9511FE19
FP20: BADF8FAB5EA0AC03 FB1B5F3E155DFC16 BF4F93F81DF85CDC 6BB59FD0B654FDB2
FP24: 683EDFEFFDC96E9B BEDFBFAEDDE2ECFF A54FF7DFE4DFFDE6 B61F4F6ECFBCFED1
FP28: 7F5BAEADCFD2D479 7C44375C0ED1897A BC5FEBBE5E41FCBF 9F1001C38F79FEF9
FPSCR: 82004000
r0 : native kernel module Kickstart/intuition.library.kmod+0x0007010C
Stack Backtrace:
019BBFF0: 2F9D0000 cmpwi cr7,r29,0
019BBFF4: 409EFFE0 bne+ cr7,0x19BBFD4
019BBFF8: 2F900000 cmpwi cr7,r16,0
019BBFFC: 419E0010 beq- cr7,0x19BC00C
>019BC000: 88100000 lbz r0,0(r16)
019BC004: 2F800000 cmpwi cr7,r0,0
019BC008: 409E0A70 bne- cr7,0x19BCA78
019BC00C: 813810A8 lwz r9,4264(r24)
019BC010: 7D234B78 mr r3,r9
019BC014: 81290190 lwz r9,400(r9)
Stack pointer (0x6FF51C30) is inside bounds
Redzone is OK (4)
68k register dump
DATA: 00000001 00000001 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 5B2A60B4 5A335304 00000000 00000000 00000000 00000000 00000000 6FF51DA0
This one is more recent, from April. On Update2. Cause was unknown. But grabbed log from buffer:
Dump of context at 0xEFFF37C0
Instruction pointer: in module Kickstart/ATIRadeon.chip+0x00009C4C (0x01B5214C)
Crashed task: input.device (0x6FF53300)
Access was a store operation
0: 0110014B 6FF42920 37006A18 00000001 54B36720 6FF42954 6FF42958 00000000
8: 00000049 0049000C 00000110 0000014B 0000000C 00000000 00000001 00000001
16: 00000006 00000000 00000000 619476D0 00000002 00000001 02260000 6FFB8700
24: 00000001 00000001 0204551C 02260000 6FFB8700 6FF42950 00000001 54B36720
CR: 48228288 XER: 40000871 CTR: 01842D00 LR: 01B4FF50
DSISR: 42000000 DAR: 00000004
FP0 : FFF8000082004000 FFFF000401000000 5000FFFF00000000 40965C0000000000
FP4 : 403F000000000000 40967F3340000000 408AEE6660000000 00000000616AA056
FP8 : 000000100008000B 0001FFFF00150013 EA2A2A2A2A2A2A2A 050000000000FA75
FP12: 00000014001E0000 0000000000000000 AC1BEFF7DAEAFCFA 3C19C7BCF7EEEE52
FP16: BE1D9EBBFBABB9FC B4BFEFEEF71FFEFF 7EFFFBCEFF7BEC7F 3D77BBFF9DBBFE39
FP20: BADF8FAF7EECFE63 FA1B5F2E15FFFC12 3F5F93FA5FFAFEDC EFB59FD8BF54FDF2
FP24: 7A3FFFEFFDC9EE9B BEDFBFAEDFE2FEFF AF4FF7DFE5DFFDE6 B61FEFEECFFFFEF3
FP28: 3F5BEFAD4FFBD67B FE5B3BAE477DFCBF BC1FEBBE5E6BFEFB 1F1201CB8F7BFEFB
FPSCR: 82004000
r26: module Kickstart/ATIRadeon.chip at 0x0204551C (section 2 @ 0xEC0)
ip : module Kickstart/ATIRadeon.chip at 0x01B5214C (section 0 @ 0x9C50)
lr : module Kickstart/ATIRadeon.chip at 0x01B4FF50 (section 0 @ 0x7A54)
ctr: module Kickstart/kernel at 0x01842D00 (section 0 @ 0x42D04)
Stack Backtrace:
(0x6FF42920) module Kickstart/ATIRadeon.chip at 0x01B5214C (section 0 @ 0x9C50)
(0x6FF42990) module Kickstart/ATIRadeon.chip at 0x01B4F5D4 (section 0 @ 0x70D8)
(0x6FF429A0) module Kickstart/rtg.library at 0x01ADCF18 (section 0 @ 0x265FC)
(0x6FF42A20) module Kickstart/rtg.library at 0x01ADE784 (section 0 @ 0x27E68)
(0x6FF42A80) module Kickstart/rtg.library at 0x01ADF57C (section 0 @ 0x28C60)
(0x6FF42B70) module Kickstart/rtg.library at 0x01AE149C (section 0 @ 0x2AB80)
(0x6FF42C30) module Kickstart/rtg.library at 0x01AF32CC (section 0 @ 0x3C9B0)
(0x6FF42C50) module Kickstart/graphics.library.kmod at 0x0197DD6C (section 0 @ 0x26CF0)
(0x6FF42CA0) module Kickstart/intuition.library.kmod at 0x019E240C (section 0 @ 0x5BD70)
(0x6FF42CE0) module Kickstart/intuition.library.kmod at 0x019E266C (section 0 @ 0x5BFD0)
(0x6FF42D00) module Kickstart/intuition.library.kmod at 0x019D5D7C (section 0 @ 0x4F6E0)
(0x6FF42D20) module Kickstart/intuition.library.kmod at 0x019A3464 (section 0 @ 0x1CDC8)
(0x6FF42D40) module Kickstart/intuition.library.kmod at 0x019D69DC (section 0 @ 0x50340)
(0x6FF42D90) module Kickstart/intuition.library.kmod at 0x019A3A44 (section 0 @ 0x1D3A8)
(0x6FF42DB0) module Kickstart/intuition.library.kmod at 0x019A3B34 (section 0 @ 0x1D498)
(0x6FF42DD0) module Kickstart/intuition.library.kmod at 0x019A3C20 (section 0 @ 0x1D584)
(0x6FF42E30) module Kickstart/intuition.library.kmod at 0x019D5DC8 (section 0 @ 0x4F72C)
(0x6FF42E50) module Kickstart/intuition.library.kmod at 0x019D686C (section 0 @ 0x501D0)
(0x6FF42E70) module Kickstart/intuition.library.kmod at 0x019D6B30 (section 0 @ 0x50494)
(0x6FF42EC0) module Kickstart/intuition.library.kmod at 0x019A3A44 (section 0 @ 0x1D3A8)
(0x6FF42EE0) module Kickstart/intuition.library.kmod at 0x019A01CC (section 0 @ 0x19B30)
(0x6FF42F00) module Kickstart/intuition.library.kmod at 0x019A02E0 (section 0 @ 0x19C44)
(0x6FF42F20) module Kickstart/intuition.library.kmod at 0x0199EC08 (section 0 @ 0x1856C)
(0x6FF42F30) module Kickstart/input.device.kmod at 0x01985EB4 (section 0 @ 0x2738)
(0x6FF42FD0) module Kickstart/kernel at 0x0181C320 (section 0 @ 0x1C324)
01B5213C: 5540801E rlwinm r0,r10,16,0,15
01B52140: 7D296378 or r9,r9,r12
01B52144: 7C005B78 or r0,r0,r11
01B52148: 38600001 li r3,1
>01B5214C: 90070004 stw r0,4(r7)
01B52150: 91270000 stw r9,0(r7)
01B52154: 4E800020 blr
01B52158: 38600000 li r3,0
01B5215C: 4E800020 blr
01B52160: 7C0800D0 neg r0,r8
Stack pointer (0x6FF42920) is inside bounds
Redzone is OK (4)
68k register dump
DATA: 6FFAAD34 5974539C 00000000 00000000 00000000 00000000 00000000 00000000
ADDR: 6FFAAD34 6139BD04 00000000 00000000 00000000 00000000 00000000 6FF42E20
----> 6139BD04 - "CalcKey" Hunk 0001 Offset 000019BC (SegList: 0x17A84EAD)
STCK: 00000001 59719D70 6FF814D0 00000050 6FF42E50 019D5DC8 80000009 618469F4
STCK: 02260000 00000001 6FF814D0 00000050 6FF42E70 019D686C 80000009 618469F4
STCK: 6FF81C16 6FF42E9C 609B7AC0 6FF814D0 6FF42EC0 019D6B30 00000003 6FF81C16
STCK: 6FE9F1FE 6FF42E90 00130000 00000000 6FF42EB0 00130000 6FF8200C 058C0000
STCK: 0014001F 6FFAAE0A 6FFAADFC 6FFAAD34 02260000 6FF814D0 6FE9EFB0 00000000
STCK: 6FF42EE0 019A3A44 80000009 618469F4 6FF81A8A 618469F4 6FF81A7C 6FF814D0
STCK: 6FF42F00 019A01CC 6FF81A7C 6FF814D0 6FF42F00 6FF81E90 6FF81A7C 6FF814D0
STCK: 6FF42F20 019A02E0 02092AB4 6FF42F50 6FFAAC5C 6FFAAD34 00000016 6FFA8788
Address of 68k IP r21 0xFFFFFFFF not found
Address of 68k IP r8 0x00000049 not found
----> 019D5DC8 - "Kickstart/intuition.library.kmod" Hunk 0000 Offset 0004F724
----> 019D686C - "Kickstart/intuition.library.kmod" Hunk 0000 Offset 000501C8
----> 019D6B30 - "Kickstart/intuition.library.kmod" Hunk 0000 Offset 0005048C
----> 019A3A44 - "Kickstart/intuition.library.kmod" Hunk 0000 Offset 0001D3A0
----> 019A01CC - "Kickstart/intuition.library.kmod" Hunk 0000 Offset 00019B28
----> 019A02E0 - "Kickstart/intuition.library.kmod" Hunk 0000 Offset 00019C3C
----> 02092AB4 - "Kickstart/kernel" Hunk 0001 Offset 00042AB0
Page information:
Page not found
Re: An input.device freeze I once caught.
Usb log after keyboard and mouse stopped. Removed then reattached.
I: [20:19:06] USB stack | | ==========
I: [20:19:06] USB stack | | USB System Software Task started
I: [20:19:06] USB stack | | Starting HCDs...
I: [20:19:06] USB stack | | ...HCDs started.
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FF8FDC0 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07010 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE071F0 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FF8FDC0 initialized
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07010 initialized
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE071F0 initialized
I: [20:19:06] hub.usbfd | HUB | All ports are empty
I: [20:19:06] hub.usbfd | HUB | Device found on port 1 of hub "Rear Roothub (ohci.usbhcd/0)".
I: [20:19:06] hub.usbfd | HUB | Device found on port 1 of hub "Additional Roothub (ohci.usbhcd".
I: [20:19:06] hub.usbfd | Hub port | Device at port 1 of hub "Additional Roothub (ohci.usbhcd" is full-speed.
I: [20:19:06] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [20:19:06] hub.usbfd | HUB | Driver Running
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE076F0 is {Vendor: 0xE305, Product: 0x0806, Class: 09.00}
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE076F0 initialized
I: [20:19:06] hub.usbfd | Hub port | Device at port 1 of hub "Rear Roothub (ohci.usbhcd/0)" is full-speed.
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07970 is {Vendor: 0x8F05, Product: 0x6663, Class: 00.00}
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07970 initialized
E: [20:19:06] MassStorage Device Task | Massstorage | Lun 0 has device type 0x00 (Direct access) and is removable
I: [20:19:06] hub.usbfd | HUB | Device found on port 1 of hub "USB2.0 Hub".
I: [20:19:06] hub.usbfd | Hub port | Device at port 1 of hub "USB2.0 Hub" is low-speed.
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07C90 is {Vendor: 0xB404, Product: 0x8180, Class: 00.00}
I: [20:19:06] hub.usbfd | HUB | Device found on port 2 of hub "USB2.0 Hub".
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07C90 initialized
I: [20:19:06] hub.usbfd | Hub port | Device at port 2 of hub "USB2.0 Hub" is low-speed.
I: [20:19:06] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07F10 is {Vendor: 0x0B04, Product: 0x3365, Class: 00.00}
I: [20:19:06] USB Fkt Init | Init Fkt | Fkt 0x5FE07F10 initialized
I: [20:19:06] MassStorage Device Task | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [20:19:06] USB stack Process | | USB System Software Process started.
I: [20:19:06] USB stack Process | | Reading FD descriptors...
I: [20:19:06] USB stack Process | | FD infos read
I: [20:19:06] USB stack Process | Rebind FD | Weak FD for Ifc 0x5FE09100 is being preempted.
I: [20:19:06] USB stack Process | Rebind FD | Weak FD for Ifc 0x5FE09180 is being preempted.
I: [20:19:06] USB stack Process | | Starting HCDs...
I: [20:19:06] USB stack Process | | ...HCDs started.
I: [20:19:06] USB stack Process | | USB stack fullbooted
I: [20:19:06] USB FD fkt start | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [20:45:10] hid.usbfd | HID Server | Interrupt req. returned -35
I: [20:45:10] hub.usbfd | HUB | Status Change Pipe error -35
I: [20:45:13] hub.usbfd | HUB | Detaching Function removed from hub port 1
I: [20:45:13] hub.usbfd | HUB | Port 1 of hub "Additional Roothub (ohci.usbhcd" disabled - port is empty.
I: [20:45:13] hub.usbfd | HUB | Device found on port 1 of hub "Front Roothub (ohci.usbhcd/1)".
I: [20:45:13] hub.usbfd | Hub port | Device at port 1 of hub "Front Roothub (ohci.usbhcd/1)" is full-speed.
I: [20:45:13] USB stack | New Fkt | HCD failed to add/create Fkt
W: [20:45:13] hub.usbfd | HUB | Retrying attachment on port 1 of hub "Front Roothub (ohci.usbhcd/1)" (previous attempt failed with error -19)
I: [20:45:13] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [20:45:13] USB Fkt Init | Init Fkt | Fkt 0x5FE076F0 is {Vendor: 0xE305, Product: 0x0806, Class: 09.00}
I: [20:45:13] USB Fkt Init | Init Fkt | Fkt 0x5FE076F0 initialized
I: [20:45:13] hub.usbfd | HUB | Device found on port 1 of hub "USB2.0 Hub".
I: [20:45:13] hub.usbfd | Hub port | Device at port 1 of hub "USB2.0 Hub" is low-speed.
I: [20:45:13] hub.usbfd | HUB | Device found on port 2 of hub "USB2.0 Hub".
I: [20:45:13] USB Fkt Init | Init Fkt | Fkt 0x5FE07E70 is {Vendor: 0xB404, Product: 0x8180, Class: 00.00}
I: [20:45:13] USB Fkt Init | Init Fkt | Fkt 0x5FE07E70 initialized
I: [20:45:14] hub.usbfd | Hub port | Device at port 2 of hub "USB2.0 Hub" is low-speed.
I: [20:45:14] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [20:45:14] hub.usbfd | HUB | Driver Running
I: [20:45:14] USB Fkt Init | Init Fkt | Fkt 0x5FD0B020 is {Vendor: 0x0B04, Product: 0x3365, Class: 00.00}
I: [20:45:14] USB Fkt Init | Init Fkt | Fkt 0x5FD0B020 initialized
Hypex
Post by Hypex »
I find this hidden feature useful. :-) That said I have another log. I had AmiUpdate scanning in the background while I using OWB to put up an ad. My system froze. I have a USB mouse with a PS/2 converter that can help as it can be pulled out and put back in. Sometimes that works. The only way to reactivate a PS/2 mouse when input is lost.
However this time once again USB failed to come to the rescue. I pulled my mouse and plugged it in again, no change. Pull it out and plug in my front USB. No movement and light underneath is dim suggesting dead system. I also have tried USB keys before to see if they flash.
Here's the log. A task called ButtonAnimTask crashed. Need to locate who that is.
missing fb-root, defaulting to fragment-based xdcomm
Dump of context at 0xEFAF0000
Instruction pointer: in module Kickstart/kernel+0x00017B88 (0x01817B88)
Crashed process: ButtonAnimTask (0x5333FD90)
0: 5864AC9A 5169BEE0 00000000 6FF2B1D4 00000000 00000000 00000001 00000008
8: 6FF2B1B8 00000001 00000000 01817BA0 48444084 00000000 000000FF 00000053
16: 00000000 5F542AE8 00000060 02260000 00000008 00000021 00000021 00000053
24: 6FF2B1D4 000000C0 5169BFCA 02260000 6FF2B150 00000000 543B74D8 6FF2B1B8
CR: 28444082 XER: 00000000 CTR: 01817BA0 LR: 01AD00C0
FP0 : FFF80000A3004000 538F0580609A5B80 0000000000000000 4072000000000000
FP4 : 0000000000000000 4077FCCCC0000000 4054B33340000000 00000000618B3056
FP8 : 000000120009000C 0001FFFF00150014 EA2A2A2A2A2A2A2A 0000000000000000
FP12: 0000000000000000 0000000000000000 AC7BEFF7DAE0F8DA 1C8957BCC7EE6E5A
FP16: BC9D9EBAFBABB9FC B4BFEFEEF10FF67F FBF7FBCE7F7AEC7F 7D77BB9F9DB3FE39
FP20: BADF9FAF5EE4EE43 FB1B5F2E353DFC16 3F5E93FA1DFA7EDC 6FB59FD0BED4FD92
FP24: 7A3EFFEFFDC9EE9B BEDFBFAEFDE2EEFF A74FF7CFE5DFFDE6 B61F6F6ECFFEFFF3
FP28: 7FFBEEADCFDED679 7C5A3BAE076CCCBF B85FEBBA5E41FEBB 1F1001C38F7BFEF9
FPSCR: A3004000
r11: module Kickstart/kernel at 0x01817BA0 (section 0 @ 0x17BA4)
ip : module Kickstart/kernel at 0x01817B88 (section 0 @ 0x17B8C)
lr : module Kickstart/rtg.library at 0x01AD00C0 (section 0 @ 0x197A4)
ctr: module Kickstart/kernel at 0x01817BA0 (section 0 @ 0x17BA4)
Stack Backtrace:
(0x5169BEE0) module Kickstart/kernel at 0x01817B88 (section 0 @ 0x17B8C)
(0x5169BF10) module Kickstart/rtg.library at 0x01ACC2C4 (section 0 @ 0x159A8)
(0x5169C080) module Kickstart/intuition.library.kmod at 0x01987978 (section 0 @ 0x12DC)
(0x5169C0F0) module Kickstart/intuition.library.kmod at 0x019883D8 (section 0 @ 0x1D3C)
(0x5169C110) module Kickstart/kernel at 0x01842684 (section 0 @ 0x42688)
(0x5169C160) module Kickstart/layers.library.kmod at 0x01A1C640 (section 0 @ 0x764)
(0x5169C1F0) module Kickstart/graphics.library.kmod at 0x01961E24 (section 0 @ 0xADA8)
(0x5169C230) module CLASSES:images/bevel.image at 0x7FDCAC98 (section 5 @ 0x3C78)
(0x5169C360) module CLASSES:images/bevel.image at 0x7FDCB448 (section 5 @ 0x4428)
(0x5169C3E0) module Kickstart/intuition.library.kmod at 0x0199E71C (section 0 @ 0x18080)
(0x5169C440) module Kickstart/intuition.library.kmod at 0x0199E940 (section 0 @ 0x182A4)
(0x5169C4C0) module Kickstart/intuition.library.kmod at 0x019A1480 (section 0 @ 0x1ADE4)
(0x5169C540) module Kickstart/intuition.library.kmod at 0x019A15A0 (section 0 @ 0x1AF04)
(0x5169C5F0) module CLASSES:gadgets/button.gadget at 0x7FFC08EC (section 5 @ 0x18CC)
(0x5169C700) module CLASSES:gadgets/button.gadget at 0x7FFC11F0 (section 5 @ 0x21D0)
(0x5169C7D0) module Kickstart/intuition.library.kmod at 0x0199E71C (section 0 @ 0x18080)
(0x5169C830) module Kickstart/intuition.library.kmod at 0x0199E940 (section 0 @ 0x182A4)
(0x5169C8B0) module Kickstart/intuition.library.kmod at 0x0199ECB0 (section 0 @ 0x18614)
(0x5169C930) module Kickstart/intuition.library.kmod at 0x0198E36C (section 0 @ 0x7CD0)
(0x5169C960) module CLASSES:gadgets/button.gadget at 0x7FFBF664 (section 5 @ 0x644)
(0x5169C980) module CLASSES:gadgets/button.gadget at 0x7FFBFD1C (section 5 @ 0xCFC)
(0x5169CAA0) module CLASSES:gadgets/button.gadget at 0x7FFC1C28 (section 5 @ 0x2C08)
(0x5169CB70) module Kickstart/intuition.library.kmod at 0x0199E71C (section 0 @ 0x18080)
(0x5169CBD0) module Kickstart/intuition.library.kmod at 0x0199E940 (section 0 @ 0x182A4)
(0x5169CC50) module Kickstart/intuition.library.kmod at 0x01995AA0 (section 0 @ 0xF404)
(0x5169CC80) module Kickstart/intuition.library.kmod at 0x0198EC98 (section 0 @ 0x85FC)
(0x5169CD00) module Kickstart/intuition.library.kmod at 0x019A3354 (section 0 @ 0x1CCB8)
(0x5169CD20) module Kickstart/intuition.library.kmod at 0x019D82EC (section 0 @ 0x51C50)
(0x5169CD80) module Kickstart/intuition.library.kmod at 0x019A3A74 (section 0 @ 0x1D3D8)
(0x5169CDA0) module Kickstart/intuition.library.kmod at 0x019A3BD8 (section 0 @ 0x1D53C)
(0x5169CE00) module Kickstart/intuition.library.kmod at 0x0198EDD8 (section 0 @ 0x873C)
(0x5169CE10) module Kickstart/intuition.library.kmod at 0x0198DF98 (section 0 @ 0x78FC)
(0x5169CE30) module Kickstart/intuition.library.kmod at 0x0198E06C (section 0 @ 0x79D0)
(0x5169CE60) module Kickstart/intuition.library.kmod at 0x0198E65C (section 0 @ 0x7FC0)
(0x5169CED0) module AmiUpdate at 0x7E3C9150 (section 5 @ 0x21130)
(0x5169CF90) module Kickstart/dos.library.kmod at 0x0191B3A4 (section 0 @ 0x1B528)
(0x5169CFC0) module Kickstart/kernel at 0x0183CD50 (section 0 @ 0x3CD54)
(0x5169CFD0) module Kickstart/kernel at 0x0183CDD0 (section 0 @ 0x3CDD4)
(0x5169CFE0)
01817B78: 7C0803A6 mtlr r0
01817B7C: 38210010 addi r1,r1,16
01817B80: 4E800020 blr
01817B84: 80030000 lwz r0,0(r3)
>01817B88: 90640004 stw r3,4(r4)
01817B8C: 90040000 stw r0,0(r4)
01817B90: 90830000 stw r4,0(r3)
01817B94: 81240000 lwz r9,0(r4)
01817B98: 90890004 stw r4,4(r9)
01817B9C: 4E800020 blr
Stack pointer (0x5169BEE0) is inside bounds
Redzone is OK (4)
68k register dump
STCK: 0000FFFF 021A6876 0000FFFF 021A6876 0000FFFF 021A6876 0000FFFF 021A6876
STCK: 0182CCA0 0182A154 0182CCA0 0182A154 0182CCA0 0182A154 0182CCA0 0182A154
Address of 68k IP r21 0x0000001F not found
Address of 68k IP r8 0x6FF2B1B8 not found
----> 021A6876 - "Kickstart/kernel" Hunk 0001 Offset 00156872
Page information:
Page not found
Rigo
Post by Rigo »
ButtonAnimTask belongs to AmiUpdate. There have been a few fixes in that area recently as I've seen similar crashes. No idea why though, it's been rock-solid up until now. Ho-hum.
As far as just "throwing" crashlogs around, it isn't really going to be very useful unless you can
1) reproduce it, and
2) supply the steps required to reproduce the crash.
While there is plenty of information in the crashlogs, without knowing just what was going on at the time, they are pretty useless.
Simon
Hypex
Post by Hypex »
Rigo wrote:ButtonAnimTask belongs to AmiUpdate.
Well that's at least something. I did suspect as much. Now why hasn't it found that new version? ;-)
BTW I have found it can delay looking for a new version. At first it happened when the network was busy, which Roadshow tends to get all internet using tasks stuck on. But tonight it wasn't busy and it was looking for a minute...
I fully see your point. But I have had these for a while and wanted to get them out there. Just incase a function offset can be checked to make sure no rogue bugs have been sitting in there. Of course once a codebase is updated the offets are useless but I just couldn't be silent on the issue.
OTOH I feel I have supplied all that is needed for the CPIO bug, so who's in charge of XAD? And when is the native OS4 verson coming? :-)
