New: Linux Kernel 3.8.7
Image New: Linux Kernel 3.8.7
Marcus and I have compiled a new version of the Linux kernel for the X1000. Version 3.8.7 solves problems of the Linux kernel and RadeonHD graphic board which could occur at some OpenGL-based applications just like SuperTuxKart or the Android emulator.
Downloads:
kernel-3.8.7x1000.tar.gz
vmlinux-3.8.7x1000-usb3-nouveau.tar.gz with USB3 and nouveau support. Without the modules directory. You need the modules directory from the first download above.
@marcus: Thank you very much for your Nemo patch :) Without your patch it would not have been possible to build the kernel 3.8.7.
Image Image
mechanic
Re: New: Linux Kernel 3.8.7
Post by mechanic »
xeno74 wrote: Hi,
Downloads:
Cool! Thanks.
nexus wrote:But why does the penguin looks so sad? ;)
nexus
His squeaker is broken...
And ... Does the new kernel work? Are you satisfied with the new kernel?
By the way Lubuntu 13.04 PowerPC is available: http://cdimage.ubuntu.com/lubuntu/relea ... 4/release/ :)
trevordick
A-Eon Technology
A-Eon Technology
Post by trevordick »
Thanks xeno74
I will gives the new kernel I try and report back.
Trevor
I'm just Breezin'
Anniversary
10 years ago, I released my first kernel for the X1000.
xeno74 wrote: Wed Apr 17, 2013 9:39 am Image New: Linux Kernel 3.8.7
Downloads:
Image Image
sailorMH
Post by sailorMH »
Just now I spot this!
Ten years, great ! Thank you very much for your support and excellent work.
