Hi there,
Unfortunately I had to reinstall my SDK. Afterwards I tried to update using AmiUpdate and got quite a few entries listed. But when trying to update them this does not work. AmiUpdate shows the following error for each component it wants to download:
22:06:53 Starting update of 'libFreetype2.lha'
22:06:53 Requesting HTTP header file from server...
22:06:53 Testing for active network connections...
22:06:53 Found interface VIA-RHINE, testing...
22:06:53 Interface is currently configured, checking state...
22:06:53 Interface is UP, check complete
22:06:53 Trying to connect to: megadrive.dlinkddns.com on port: 80
22:08:08 Failed
22:08:08 Failed to establish connection to: ftp.uprough.net error: Connection to the server failed
22:08:08 Failed to receive HTTP header file...
22:08:08 Error returned from downloading file 'libFreetype2.lha': Übertragung fehlgeschlagen
22:08:08 Update finished
Any idea what's wrong here? Did the server change (AFAIK I always switched to new server entries sooner or later not missing any)?
Many thanks in advance and
Best Regards
AmiUpdate SDK Server down?
Re: AmiUpdate SDK Server down?
Problem solved:
I added ftp.uprough.net/AmiUpdate/ to the servers list (was somehow missing) and now it works fine).
Bye
Bye
