How to reproduce it step by step:
Say that you have a program in your dock and you want to reach its original folder directory, so:
1 - First be sure that the complete directories where your programs reside are setted and saved to be showed in lister mode only
2 - Now if you have one of this program on your AmiDock (if not, add a program on it to do this simple test)
3 - Now right click on the dock icon of the program you want (for example YAM) and choose from dock --> Reveal in Workbench
4 - Now you should have the YAM directory opened on your WB, if so then from your WB menu select: window --> Open parent
5 - This will open the previews main directory, now search your YAM folder
I have this result:
http://imageshack.us/photo/my-images/98/listerbug.png/
As you can see from this grab the YAM folder have its name hidden, not a big problem for sure but still ...
