Notification Prefs and ClickToFront issue
Apparently the new Notification Prefs (53.24) does not work correctly with the latest ClickToFront 53.10, tester please can you check it ?
Re: Notification Prefs and ClickToFront issue
Confirmed, doens't work. Will ask on beta-list and then make a BZ (dunno for what currently, to notifications or its again click2front)
Most probably it's not the commodity but the Notification prefs, a couple of weeks ago we had a samilar problem with NetSurf. then it was fixed.
Eventually the problem might be caused by the same "wrong method" used, check this thread:
http://www.amigans.net/modules/xforum/v ... mpost77933
What was the problem? Was it a missing WA_PubScreen tag, just like it was in the case of NetSurf?kas1e wrote:fixed
The Rear Window blog
@Trixie
I do not know, as i only see that it was fixed in beta which i test + there few words like "fixed issue with c2f", without much information.
ps. just in case: did you get my last mail ?:)
@samo79
Yeah, i am aware of amigans.net thread, but i also aware that ppls in that thread was unclear what it happens at all because it should't. So for me and others it still bug in c2f, which need to fix in c2f as well to avoid problems in future. Fixing it in netsurf and in notification mostly like making workorounds for bug which will happens soon or later. Just i do not know how fill BZ for c2f .
@samo79
That's fine, the important thing is that the bug has been fixed, next time we will report eventual new bugs to the commodity
The last one I got was from 21 March, which I already replied to. Did you send another one?kas1e wrote:@Trixie
@Trixie
Check pm plz
Check pm plz
I have the same problem with the LogViewer tool, the window doesn't front up with ClickToFront
