Is the PCIe 1x-Slot of the SAM460ex DMA buffered?
I´m asking, because i plan to put there a Soundcard into it. Is the PCIe 1x ESI Juli@Xte-Card working on that slot with the Envy24HT AHI driver?
The onboard-Sound make crackling sounds in high CPU-Load situations. I have checked if there´s a missing 0Ohm Resitor but it´s there. Sadly my PCI-Slot is blocked by the SiL3114-Card, so i have no other choice.
PCIe 1x and ESI Juli@Xte
Re: PCIe 1x and ESI Juli@Xte
Max reported on Amigaworld that the Juli@Xte works.
http://amigaworld.net/modules/newbb/vie ... at&order=0
See post # 40.
Quote:
About a PCIe solution for the 1x slot, has been reported to us the ESI Juli@ XTE card works correctly with current AHI drivers.
See post # 40.
Its now fully confirmed at AW net http://amigaworld.net/modules/newbb/vie ... 6&forum=33Mozzerfan wrote:Max reported on Amigaworld that the Juli@Xte works.
See post # 40.
However, even its low latency, 24-bit sound card, cheapest one could find it is 155eur here http://www.thomann.de/gb/esi_juli_xte.htm
If someone find its cheaper, please report.
Also before buy would be interested to know how much better sound is from e.g. EMU101 card like Sound Blaster Live
Future MOS user pon SAM460ex
It´s really a nice Card and it´s money worth.
What is missing is surely the Mixer-Support or a solution to control the Mastervolume (Mute, Voluup and Voldown).
I havent tried yet but if AHI has AREXX support you could achieve at least master volume up and down through it.fingus wrote:It´s really a nice Card and it´s money worth.
Im "suffering" from the same problem (using a Juli@ here myself) and hope to be able to somehow use AHI directly for master volume up/down.
Right now im using the volume sliders from the third party programs im usin (AmigaAmp, PlayCD etc.)
As far as I have understood, there is no mixer component in the Juli@ cards, which is why the Mixer program does not support them, it has nothing to mix.
But having a convenient master volume control would be nice, I agree. I think there are some solutions out there. Didn't HunoPPC just release something along those lines?
Several people have the SBLive! card including myself. I love it.vox wrote: Also before buy would be interested to know how much better sound is from e.g. EMU101 card like Sound Blaster Live
Should you decide to get one make sure it is either a SB 0220 or SB 0100. They are
the same except the 0220 can output to a digital sound system, but I have never seen
a digital sound system in the wild and no idea if one would work with most cards.
There are other SoundBlaster cards, I will recommend to stay away from those without
the above numbers.
That would be enough. So i can use it with my own Ringhio-Soundbar:Raziel wrote:I havent tried yet but if AHI has AREXX support you could achieve at least master volume up and down through it.
Unfortunately, as i have learned lately, AHI does not feature AREXX support.
You have to use the 3rd party play progams and its ability to change the volum to do so...sorry
where can i get that volumebar thingy ???
looks nice and if its functional its realy handy.
