ExamineObject()
Coder
ExamineObject()
Post by Coder »
Am I correct in saying that now to get all the file info from a file you should use ExamineObject()?
Coder
abalaban
Re: ExamineObject()
Post by abalaban »
Coder wrote:Hi,
Indeed you are right!
AmigaOne XE/G4
Re: ExamineObject()
You'll find it a hell of a lot easier than the old way. Faster, too.
Coder
Re: ExamineObject()
Post by Coder »
@abalaban/Tony
Thanks. I read the dos library autodoc and did notice some changes including the ExamineObject(). I have not seen any examples around on the net using the ExamineObject().
Coder
abalaban
Re: ExamineObject()
Post by abalaban »
Simplified example from my CompareDirs tool :
	int32 success= FALSE;
	APTR context = IDOS->ObtainDirContextTags( EX_StringNameInput, dirname,
                                        EX_DoCurrentDir,TRUE, /* for recursive lock */
                                        EX_DataFields,(EXF_NAME|EXF_LINK|EXF_TYPE|EXF_SIZE|EXF_DATE),
                                        TAG_END);
	if (context)
		struct ExamineData *dat;
		while ((dat = IDOS->ExamineDir(context)))
			if ( EXD_IS_DIRECTORY(dat))
				IDOS->PrintF("%s is a directory\n", dat->Name);
			else
				int64 fileSize = dat->FileSize;
				if ( EXD_IS_LINK(dat) )
				{ // it's a link try to resolve it
					struct ExamineData * linkedobj=
									IDOS->ExamineObjectTags(EX_StringNameInput,dat->Link,TAG_END);
					if (linkedobj)
						fileSize = linkedobj->FileSize;
						IDOS->PrintF("%s is a link to %s whose size is %lld\n", dat->Name, linkedobj->Name, fileSize);
						IDOS->FreeDosObject(DOS_EXAMINEDATA, linkedobj);
						linkedobj = NULL;
				else
					IDOS->PrintF("%s is a file whose size is %lld\n", dat->Name, fileSize);
		if ( ERROR_NO_MORE_ENTRIES == IoErr())
			success = TRUE; /* normal exit */
		else
			UI->error( _T(MSG_ERR_EXAMINING_DIR) ); /* failure - why ? */
	else
		UI->error( _T(MSG_ERR_OBTAINING_DIR_CONTEXT) ); /* failure - why ? */
	IDOS->ReleaseDirContext(context); /* NULL safe */
You have examples of both ExamineObject (to resolve the link) and ExamineDir, ask if you want more. I'll probably create an article in the wiki about this.
AmigaOne XE/G4
cha05e90
Re: ExamineObject()
Post by cha05e90 »
abalaban wrote:I'll probably create an article in the wiki about this.
Pretty, pretty please! :P
Coder
Re: ExamineObject()
Post by Coder »
@abalaban
Thanks for the example! That will get me started.
Coder
colinw
Re: ExamineObject()
Post by colinw »
if ( EXD_IS_LINK(dat) && 0 == fileSize)
Please avoid making assumptions like this, the filesize has no bearing on whether something is
a linked object or not.
Please distribute only example code provided in the latest autodoc file; dos.doc et al.
I believe the latest SDK files will be publicly distributed shortly.
tboeckel
Re: ExamineObject()
Post by tboeckel »
Coder wrote:I have not seen any examples around on the net using the ExamineObject().
Then you didn't look carefully enough. YAM is using ExamineObject() from the very first day since this function started to exist.
abalaban
Re: ExamineObject()
Post by abalaban »
colinw wrote:[...]
Yes Colin, you are right, it was a short example I extracted from an existing code and in this code I had to resolve the link only when the fileSize was 0. The fact it has null size does not imply anything on the fact the file is a link or not of course.
Source code modified to prevent bad assumptions.
AmigaOne XE/G4
