If you open NotePad, type sone text or not, then move the mouse pointer just below the cursor and press the RMB, you will notice the Menu has a "hole" just where the cursor is. In contrast, if you select some text, the menu did not went by a swiss cheese manufacturing facility.
A similar effect can be see in WBPattern-Prefs.
- click on a Text-Field, e.g. the one for "Picture name" on the "Workbench" tab
- now move the mouse pointer just above the border of the String-gadget-field and click the Right Mouse Button to show the Menus.
you will notice the menu is missing all along the lenght of the gadget.
This happens only on the first click. Maybe some fidling is needed to find the exact pixel point just above the text-field for the ecffect to appear.
that's all.. I'll go back hunting..
