From shell assign hd4: dismount
Then I accidently clicked my hd4 (rmb)
I got guru.
I can duplicate this, every time
System: Peg2/G4, 1 gm mem, radeon 9250.
Yes, that's the latest version.mlehto wrote: I have 53.1 (30.11.09)
Amiupdate doesnt find anything newer.
I think it is newest (?)
Good to hear that the problem is gone.mlehto wrote:I made clean install with updates recently, after I changed hd, psu, graphics card and memory module to my peg2.
Have to say that now this works.
For a safe way to dismount a filesystem that frees all it's associated resources you should use the Dismount command without its FORCE switch. The FORCE switch of C:Dismount makes it act in the same way that "Assign DISMOUNT" does.The DISMOUNT option used with a device name can be used to dismount
the device and all volumes that belong to the device. This feature
was added in version 51.14 and requires dos.library V51.30+, if
one of this requirements is missing the DISMOUNT option for devices
will work like the DISMOUNT option for volumes (see below).
Note: It depends on the filesystem/handler if dismounting a device
is supported or not. When its not supported, the device and the
volumes which belong to it are disconnected from the device and
volumes lists.
Warning: The DISMOUNT option (called REMOVE in V1.3) used with a volume
name disconnects the volume from the list of mounted volumes. It does
not free up resources; it merely removes the name from the list. There
is no way to cancel a DISMOUNT used with a volume name without
rebooting. DISMOUNT on volume names is primarily for use during
software development. Careless use of this option may cause a software
failure.
