Is there a supported PCIe ethernet card?
mbrantley
Post by mbrantley »
Is there a supported PCIe ethernet card that will work with AmigaOS on my X1000?
I currently use the provided PCI ethernet card in a PCIe adapter, but I'd like to have something more secure and less "wiggly." I may investigate a more secure mount for what I've got (perhaps just need a half-height bracket for the PCI card), but if there's an inexpensive PCIe card out there that will work, I'd order it.
I relocated the PCI ethernet card to allow for the installation of a CatWeasel Mark IV card.
Of course, support for the onboard ethernet port would be the most ideal solution, but I suspect that's a ways off since there are bigger fish to be fried.
trevordick
A-Eon Technology
A-Eon Technology
Re: Is there a supported PCIe ethernet card?
Post by trevordick »
Not that I'm aware of? There was a suggestion that there was OS4 drivers for one of the PCi-e Network cards but test proved fruitless.
Trevor
I'm just Breezin'
mbrantley
Post by mbrantley »
OK. Thanks for the information, Trevor.
