DSI error upon every right-click on an AppIcon
I got a DSI error always when I try to right-click on an AppIcon on the Workbench. Does anyone have the same problem with the last updates?
Re: DSI error upon every right-click on an AppIcon
If i get it right, then it public ContextMenu bug, fixed in the beta ones, there is relevant thread.
Yes Roman, that's exactly the same behaviour, although my system freezes completely. Thanks for the links.
