I encounter a problem on which I have no solution.
Due to the structure of the AmiDARK Engine, audio is defined this way :
1. Function to load an object : DELoadSound( File, ID )
2. Function to play/pause/resume/stop object : DEPlaySound( ID ), DEPauseSound( ID ), DEResumeSound( ID ), DEStopSound( ID )
3. Function to delete object : DEDeleteSound( ID )
I can load an audio using datatype, delete it without problem.
The problem is when I want to play it.
I copy the functions there to show you :
void DELoadSound( char *szFilename, int iID ){
// ULONG res;
// uint32 longueur ;
if ( iID > 0 ){
if ( iID < 257 ){
if ( DESoundExist( iID ) == 0 ){
if( DEFileExist( szFilename ) == TRUE ){
AESound[ iID ].ObjectPTR = IDataTypes->NewDTObject( (STRPTR)szFilename,
DTA_SourceType, DTST_FILE,
DTA_GroupID, GID_SOUND,
SDTA_Volume, 63,
// SDTA_SignalTask, (ULONG)IExec->FindTask(NULL),
// SDTA_SignalBitMask, END_SOUND_SIGNAL,
TAG_END );
if ( AESound[ iID ].ObjectPTR != NULL ){
AESound[ iID ].Exist = TRUE;
AESound[ iID ].Loop = FALSE;
AESound[ iID ].Playing = 0;
AESound[ iID ].FileName = LCreateString( 256 );
LCopyString( szFilename, AESound[ iID ].FileName );
AESound[ iID ].Audio3D = 0 ; // This sound IS NOT a 3D Audio sound.
}else{
printf( "DELoadSound Warning : Object not created\n" );
AESound[ iID ].Exist = FALSE;
void DEPlaySound( int iID ){
if ( DESoundExist( iID ) == 1 ){
if ( AESound[ iID ].Playing != 0 ){
DEStopSound( iID );
mydtt.MethodID = DTM_TRIGGER;
mydtt.dtt_GInfo = NULL;
mydtt.dtt_Function = STM_PLAY;
mydtt.dtt_Data = NULL;
AESound[ iID ].dores = IDataTypes->DoDTMethodA( AESound[ iID ].ObjectPTR, NULL, NULL, (Msg)&mydtt );
IExec->Wait( SIGBREAKF_CTRL_C );
AESound[ iID ].Playing = 1;
When I use these functions from a fresh project (that'll use the libAmiDARK.a lib), here is the problem I encounter.
1. With the line "IExec->Wait( SIGBREAKF_CTRL_C );" removed : No audio playback.
2. With the line "IExec->Wait( SIGBREAKF_CTRL_C );" not removed : audio playbak but program lock infinitely. and I cannot quit the application nor doing anything from the moment the sample started to play.
Here the source code I use to test the DEPlaySound function :
#include "libamidark.h"
int InKey;
void DarkLoop( void ){
// Setup Display.
DESetDisplayMode( 640, 480, 32 );
DESyncOn();
DESyncRate( 60 );
// Load the 4 samples using DataTypes.
DELoadSound( "Medias/oceanwave.wav", 1 );
DELoadSound( "Medias/break.wav", 2 );
DELoadSound( "Medias/DREAM.WAV", 3 );
DELoadSound( "Medias/electricarc.wav", 4 );
DELoadImageEx( "Medias/AmiDARK_Engine_Logo v2.png", 1, 1 );
InKey = 0;
while( !DELoop() ){
DECls();
DESetCursor( 0, 0 );
DEPrint( "AmiDARK Engine now play Audio Sounds using DATATYPES" );
DEPrint( "Press default QUIT KEY to stop this demonstration example." );
DEPrint( " " );
DEPrint( "Press 1 to play OceanWave.wav" );
DEPrint( "Press 2 to play Break.wav" );
DEPrint( "Press 3 to play Dream.wav" );
DEPrint( "Press 4 to play ElectricArc.wav" );
// Keyboard key 1 to 4 start replay of a sound.
InKey = DEScancode(); InKey--;
if ( InKey > 0 ){
if ( InKey < 5 ){
DEPlaySound( InKey );
DEPasteImageEx( 1, DEBitmapWidth( 0 ) - ( DEImageWidth( 1 ) + 4 ), 4, 1 );
DESync();
// We delete sounds from memory.
for ( InKey = 0; InKey < 5; InKey++ ){
DEStopSound( InKey );
DEDeleteSound( InKey );
when you press a key from 1-4 it start play a sample.
So, due to this way of working, I cannot use Wait functions to wait the sound finished.
(do you see in a game a ship fire a projectyle and the game pause until the sound is finished ? :p)
So, Does someone have an idea on how I can fix this problem ?
Thank you.
Kindest Regards,
AmiDARK
