Is it impossible or just userfailure?
System is os4.1 a1g3-se
And yes, my battery is fine, thank you
solved using a sii3114, hd on port 0, dvd on port 3satiropan wrote:almost same problem on my a1g3se
hd on sii3112 sata port 0
dvdrw on sii3112 sata port 1
no problem in booting with hd
but won't boot from aos4.1 cdrom
seems uboot fails to recognize the dvdrw sata drive (sort of, has no time to recognize the drive)
no problem in booting from cd if I use pata dvdrw connected as master to internal ide primary
