JFX Partition Problems [SOLVED]
klapdeur
Post by klapdeur »
Hi guys Awhile ago ive put a extra hdd (SSD) into my amigaone 500 partitions made tried several time to ad a JFX partition but it never shows up into WB ones booted, so i can't format the partition.
in the beginning i had a working jfx partition but it just doesnt show up.
any help please....
Re: JFX Partition Problems
Your new HDD won't show up unless you change the env-variable xxx_conf to include it.
How is it connected? SATA? Which device is supporting SATA in that machine?
klapdeur
Post by klapdeur »
i now have two hdd inside, 1 boot is SSD and second my old 500gb sata drive both show up but not if change a partition on the 500gb disk from sfs/02 to jfx as long i choose FFS or SFS nothing wrong and partitions are shown and can be formated but as soon i select jfx filesystem after a reboot all partition are shown expect the jfx one so i cant format it.
thats the problem, jfx filesystem is loaded in the kicklayout
klapdeur wrote:i now have two hdd inside, 1 boot is SSD and second my old 500gb sata drive both show up but not if change a partition on the 500gb disk from sfs/02 to jfx as long i choose FFS or SFS nothing wrong and partitions are shown and can be formated but as soon i select jfx filesystem after a reboot all partition are shown expect the jfx one so i cant format it.
The block size for JXFS must be 512. If it isn't, the partition won't even show up.
klapdeur
Post by klapdeur »
thnx blocksize was the problem
problem Solved
Slayer
Post by Slayer »
change your title to include solved please
