Strange libz behaviour
I haven't done much with this library, actually it only gets used here in ports that use libpng...but then the beast bites.
I had problems getting anything to build with that library (not sure if it is sdk material or third party)
I got a ld warning that libz is needed by libpng but everything was installed fine.
Snoopy gave the answer then:
The SDK is looking for libz here:
01242 : ld              : FAIL = Open("gcc:ppc-amigaos/lib/libz.so",OLD) = [0x00000000] [56uS]
01243 : ld              : FAIL = Open("gcc:ppc-amigaos/lib/libz.so",OLD) = [0x00000000] [47uS]
01244 : ld              : FAIL = Open("gcc:lib/libz.so",OLD) = [0x00000000] [46uS]
01245 : ld              : FAIL = Open("usr:local/lib/libz.so",OLD) = [0x00000000] [63uS]
01246 : ld              : FAIL = Open("lib:libz.so",OLD) = [0x00000000] [45uS]
01247 : ld              : FAIL = Open("usr:lib/libz.so",OLD) = [0x00000000] [44uS]
01248 : ld              : FAIL = Open("gcc:ppc-amigaos/lib/libz.so",OLD) = [0x00000000] [47uS]
01249 : ld              : FAIL = Open("gcc:ppc-amigaos/lib/libz.so",OLD) = [0x00000000] [46uS]
01250 : ld              : FAIL = Open("gcc:lib/libz.so",OLD) = [0x00000000] [45uS]
01251 : ld              : FAIL = Open("usr:local/lib/libz.so",OLD) = [0x00000000] [46uS]
01252 : ld              : FAIL = Open("lib:libz.so",OLD) = [0x00000000] [44uS]
01253 : ld              : FAIL = Open("usr:lib/libz.so",OLD) = [0x00000000] [44uS]
while all other libs are looked for in the PATH and the path i gave with -L
Why libz isn't found is beyond me.
I worked around this issue with assigning a lib: to sdk:local/newlib/lib in user-startup.
If anyone can tell me how i can properly fix this, i'd be grateful.
People are dying.
How dare you!
– Greta Thunberg
