Tonight my AmiUpdate saw 2 updates. One Runinuae and the other a sysmon.
I did both of them.
The Runinuae gave me some errors I want to make sure are OK.
First error said I already had runinuae and do I want to keep my existing or replace. Not sure I just kept existing.
It then had these various files it kept asking if I wanted replaced or not and the text message said say YES if I was not sure, so that is what I did, clicked YES on all the rest.
I reboot after this AmiUpdate and re-ran AmiUpdate and now it no longer sees this Runinuae as needed so I am guessing all is OK but, not 100% sure.
So was I supposed to have it replace out and not keep existing on that first error or?
Going into System Rollback it does not even see I updated Runinuae today so I can't rollback to anything.
TJ
New Runinuae AmiUpdate errors.
- amigasociety
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
Re: New Runinuae AmiUpdate errors.
As a general rule, yes you should let it replace those files, which is why it says to say yesamigasociety wrote:So was I supposed to have it replace out and not keep existing on that first error or?
As far as I can tell from your post, you are not actually having any problems nor errors with RunInUAE. You were just worried about whether you did the right thing?
P.S. Even if I had added RunInUAE to AmiUpdate's RollBack system, it would only have rolled-back the main executable(s), but not any of the data files (which means none of the changes you were worried about would be reverted). I think that applies to rolling back most other programs too. FWIW, AmiSystemRestore would have allowed you to revert everything (but only if it was installed on the main SYS: partition, which is the default for RunInUAE).
