Is it possible to set up an X1000 to read classic Amiga floppies?
If so, what do I need to do that?
(I thought someone might have asked this question already, but didn't find anything when searching. Maybe my search- and Google-fu is weak)
set up to read floppies on X1000?
Re: set up to read floppies on X1000?
You need a CatWeasel PCI card and a floppy disk drive. I am doing this with a CatWeasel Mark IV card in my X1000 after having relocated my PCI network card with a PCIe adapter to free a PCI slot. I have read that an earlier version of the CatWeasel will be going back into production. The one I have does not seem to be available anymore.
Hmm, the current lack of CatWeasels is a hurdle, yes.
Anyway, thanks for telling me what is needed.
Torfinn
mbrantley wrote:You need a CatWeasel PCI card and a floppy disk drive. I am doing this with a CatWeasel Mark IV card in my X1000 after having relocated my PCI network card with a PCIe adapter to free a PCI slot. I have read that an earlier version of the CatWeasel will be going back into production. The one I have does not seem to be available anymore.
+ 1 have the same setup & it's working great
Catweasel like hardware could be a good project for Xena/Xorro.tingo wrote:Hmm, the current lack of CatWeasels is a hurdle, yes.
Oh, i definitely second thatRobMattin wrote:Catweasel like hardware could be a good project for Xena/Xorro.tingo wrote:Hmm, the current lack of CatWeasels is a hurdle, yes.
A xorro classic amiga floppy controller?
I would buy that!
I would buy that!
Neither the hardware design nor the software task is trivial. Granted, the software might be written for nothing by a fan with nothing better to do, but a hardware interface to a PC floppy needs to be designed and mass produced. Can you still get PC floppies with 40-pin connectors?
I don't think you'd be able to afford it, unless someone like Trevor paid for the hardware design out of the goodness of his heart.
And after all that, what do you get? The ability to read old Amiga disks which are all available on line anyway?
Buy a CatWeasel instead.
I sure hope all my floppies with backups and old letters and other personal documents aren't available onlinetonyw wrote:And after all that, what do you get? The ability to read old Amiga disks which are all available on line anyway?
That, however, is very true - if only you can find an Amiga floppy drive.Buy a CatWeasel instead.
Another possibility, which for many might be just as easy, is to set up an old A1200 or similar with networking, read the floppies on that and transfer them to the HD of an NG Amiga (or wherever) as ADFs or - for system-friendly disks - simply LhA archives.
Does os4 support kyroflux?
