Wrong typecast in GetApplicationAttrs() autodoc?
trixie
Post by trixie »
I see that the autodoc for GetApplicationAttrs() / GetApplicationAttrsA() contains the following example code:
       struct MsgPort *port;
       if (GetApplicationAttrs(appID, APPATTR_Port, (uint32)&port, TAG_DONE))
           ... receive messages ...
But surely the typecast is wrong? Assuming that the function uses the same type of storage as Intuition's GetAttrs(), I guess the line should read:
if (GetApplicationAttrs(appID, APPATTR_Port, (uint32 *)&port, TAG_DONE))
The Rear Window blog
salass00
Re: Wrong typecast in GetApplicationAttrs() autodoc?
Post by salass00 »
@trixie
It's defined as a varargs function so no cast should be necessary unlike with GetAttr() where the type of the storage pointer is defined in the function definition.
ssolie
Post by ssolie »
As salass00 already pointed out, type casting with varargs is quite irrelevant. Removing the type cast completely is the correct fix.
Hans-Joerg Frieden
Post by Hans-Joerg Frieden »
The typecasting is pretty much irrelevant, that's true. However, Trixie has a point here, it's bad style because it will produce code that is not 64 bit clean. Not that we run on any 64 bit target, but then, there is no need to artificially create these issues :)
