Hi, I'm trying to use HP Scanjet 5300c (USB) with my SAM460, how do I know what device/unit (ex.: USBblah.device/1) my scanner is using?
BTW trying to use ScanQuix5 (worked great with my A1-XE) with SAM460 (via USB HP scanjet) and everytime I try to define a new scanner it just crashes/GR. Has anyone configure an USB scanner with ScanQuix5?
TIA
USB scanner
Re: USB scanner
Jep longtime ago. an Epson Perfection 1250 USB with scanquix5-USB and the Epsonusb.device. But on OS3.9
My Epson died 2010. But you can try with AmiCygnix on OS4.1 with Xsane and USB. ( its in OS4depot.net )
- javierdlr
Re: USB scanner
@zappa
Yep, already rtied AmiCygnix, but with my HP Scanjet5300c USB it just start scanning, but aborts/stops (maybe some timeout issue). With ScanQuix I get a crash/GR
, can't remember how I configure it with my other/old Scanjet 4p SCSI. ¿:-P
Re: USB scanner
I will try these Days a EpsonPerfection1260 with AmiCygnix and xsane.
Will Report if it goes.
Re: USB scanner
Yep it works.
Xsane need some time to warmup the scanner but it works.
Poor quality need to ajust some settings. Or buy a better scanner
- javierdlr
Re: USB scanner
well the HP scanjet 5300 USB (sort of) works under AmiCygnix (SAM460ex), it makes the preview image OK, but when I try the "final/real" scan it starts but at the middel of the scannig process it timesout
I have another machine (PC) with linux in which works fine :-/
And my "old" A1-XE had a Scanjet 5p SCSI attached and with Scanqui5 no problems
(my problem now is that I don't have space in my room for sooo many machines).
- javierdlr
Re: USB scanner
ScanQuix 5 crash/GR solved by reinstalling from scratch
but how do I now what device/unit is using the USB scanner?
TIA
TIA
Re: USB scanner
Intrested in that allso.
Is there any scanner support in OS4 or is only hope to scan use amicygnix or scsi/scanner __
